[mapserver-users] How to cascade a WMTS service?
Eichner, Andreas - SID
Andreas.Eichner at sid.sachsen.de
Thu Nov 16 02:13:45 PST 2017
Hi Jukka,
GDAL uses Curl for the HTTP client. At least under Linux it respects the conventional environment variables HTTP_PROXY, HTTPS_PROXY and HTTP_NOPROXY. AFAIK at least Apache uses a cleaned environment when running CGI programs. So you might need to specify
PassEnv HTTP_PROXY HTTPS_PROXY HTTP_NOPROXY
in your httpd.conf to let them be passed through.
HTH
> -----Ursprüngliche Nachricht-----
> Von: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] Im
> Auftrag von Rahkonen Jukka (MML)
> Gesendet: Mittwoch, 15. November 2017 16:47
> An: Mapserver-Users (mapserver-users at lists.osgeo.org)
> Betreff: [mapserver-users] How to cascade a WMTS service?
> Hi,
> I would like to cascade a WMTS service. I know well how to cascade WMS
> with "connenctiontype WMS" but I suppose for cascading WMTS I must use
> GDAL instead.
> My GDAL has WMTS driver
> WMTS -raster- (rwv): OGC Web Mab Tile Service
> I have created a definition file "wmts.xml" and "gdalinfo wmts.xml" is
> OK but I do not know how to make Mapserver to cascade this service.
> I suppose that my layer is rather close to right:
> LAYER
> NAME "cascaded_wmts"
> TYPE RASTER
> STATUS ON
> DATA "wmts.xml"
> METADATA
> "wms_title" "cascaded_wmts"
> "wms_srs" "EPSG:3067 EPSG:4326"
> END
> END
> However, our server is behind a proxy. For cascading WMS with
> CONNECTIONTYPE WMS the proxy host and port can be set in the METADATA
> section http://mapserver.org/ogc/wms_client.html but so far I have not
> been able to guess how to do that for GDAL connection. Proxy settings do
> not seem to be supported as environment variables
> http://mapserver.org/environment_variables.html.
> So, is it possible at the moment to cascade WMTS through a proxy with
> Mapverver?
> -Jukka Rahkonen-
