[mapserver-users] php Mapscript queryByAttributes
Carlos Ruiz
boolean10001 at yahoo.com
Thu Oct 12 10:54:33 PDT 2017
Sven,
This is a good workarround. It's weird why the IN operator is not working for Postgres but as Steve wrote, a ticket will be opened.
On Thursday, October 12, 2017, 8:04:46 AM CDT, Sven Schroeter <schroeter at netgis.de> wrote:
Hi Steve and Carlos,
thanks for your support.
When I understand it correctly, I can not use the IN operator in conjunction with queryByAttributes in Mapserver 7 (mapscript) ?
I use this function so far for the transfer of different IDs (whether integer or string) to read out a subset of POSTGIS tables.
I have now tried the following and it works:
$qstring = "([gid] = '1' || [gid] = '2' || [gid] = '4' || [gid] = '11')";
$query_layer->queryByAttributes("gid",$qstring,MS_MULTIPLE);
Maybe it is possible to get the IN operator back in the future?
Sven
Von: Lime, Steve D (MNIT) [mailto:steve.lime at state.mn.us]
Gesendet: Mittwoch, 11. Oktober 2017 23:33
An: Carlos Ruiz; mapserver-users at lists.osgeo.org; Sven Schroeter
Betreff: RE: RE: [mapserver-users] php Mapscript queryByAttributes
Ugh, my bad. At least with the LIKE operator it’s because MapServer doesn’t support it. Using a regex should work depending on your back-end. Which reminds me, which backend are you using? I need to investigate the IN operator. It maybe that I can come up with a work around for Sven using the native SQL that worked previously since that can still be set as a processing option. Will report back…
Steve
From: Carlos Ruiz [mailto:boolean10001 at yahoo.com]
Sent: Wednesday, October 11, 2017 4:03 PM
To: mapserver-users at lists.osgeo.org; Sven Schroeter <schroeter at netgis.de>; Lime, Steve D (MNIT) <steve.lime at state.mn.us>
Subject: Re: RE: [mapserver-users] php Mapscript queryByAttributes
Hey Steve,
> the IN operator works off a delimited list, try queryByAttributes("gid", "([gid] IN ‘100,101’)", MS_MULTIPLE);. Any whitespace > is considered part of the tokens in a list.
I have tried this and it doesn't work. There's a query error because Mapserver try to add the following: and ("gid"'100,101')
> This is close, it’s a logical expression but you’re comparing a number against a string. It should be
> queryByAttributes("municipio", "(‘[municipio]’ LIKE 'G%')", MS_MULTIPLE);
I have tried this and it doesn't work. There's a query error because Mapserver try to add the following: and ("municipio"::text'G%')
Maybe this happens because the MS4W version (3.1.3) with Mapserver CGI 7.0.1
On Wednesday, October 11, 2017, 2:31:41 PM CDT, Lime, Steve D (MNIT) <steve.lime at state.mn.us> wrote:
The query syntax is given in MapServer expression syntax. I think there’s a logical expression for why you’re seeing these results:
queryByAttributes("gid", "gid > 100", MS_MULTIPLE) // does not found anything
is evaluated as gid = “gid > 100”. Valid but not what you’re looking for. Your last example is the right way to do it - queryByAttributes("gid", "([gid] > 100)", MS_MULTIPLE);. If MapServer sees the qstring is a logical expression then it ignores the qitem.
queryByAttributes("gid", "100", MS_MULTIPLE) // found one result
is evaluated as gid = 100 which makes sense.
queryByAttributes("municipio", "'GUADALAJARA'", MS_MULTIPLE) // found one result
is evaluated as municipio = GUADALAJARA which makes sense. I don’t think you need the interior quotes around GUADALAJARA though.
queryByAttributes("municipio", "municipio LIKE 'G%'", MS_MULTIPLE) // does not found anything
like the first example this evaluates as municipio = "municipio LIKE 'G%'", not what you want. See below…
queryByAttributes("gid", "([gid] IN (100, 101))", MS_MULTIPLE); // query error
the IN operator works off a delimited list, try queryByAttributes("gid", "([gid] IN ‘100,101’)", MS_MULTIPLE);. Any whitespace is considered part of the tokens in a list.
queryByAttributes("municipio", "([municipio] LIKE 'G%')", MS_MULTIPLE); // query error
This is close, it’s a logical expression but you’re comparing a number against a string. It should be queryByAttributes("municipio", "(‘[municipio]’ LIKE 'G%')", MS_MULTIPLE);
Steve
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Carlos Ruiz
Sent: Wednesday, October 11, 2017 1:36 PM
Subject: Re: [mapserver-users] php Mapscript queryByAttributes
Sven,
Doing some tests, queryByAttributes does not accept LIKE nor IN, just single values or simple operators (I am using PostGIS).
queryByAttributes("gid", "([gid] > 100)", MS_MULTIPLE); // found 25 results
MS4W version is 3.1.3
Try to solve it by using FILTER, which allows more complex expressions:
$layer->setFilter("gid IN (100, 101)");
Cheers
On Wednesday, October 11, 2017, 10:55:17 AM CDT, Sven Schroeter <schroeter at netgis.de> wrote:
Old Server: PHP 5.4.36 with MS 6.4.1 (MS4W)
New Server: PHP 5.6.31 with MS 7.0.6 (MS4W 3.2.2)
My Test Script:
$qfield = 'gid';
$qstring = "gid IN (1,2,3)";
@$datQuery = $query_layer->queryByAttributes($qfield,$qstring,MS_MULTIPLE);
Works fine on the old Server, on the new Server no result.
I have tried to change the query expression, i.e.:
$qstring = "('[gid]' in '1,2,3')";
No result on old server and new...
How can I get it run on MS7?
Thanks + greetings
Sven
NETGIS GbR
Benediktinerstr. 32a
54292 Trier
Tel.: 0651-1704731
Fax: 0651-1704733
www.netgis.de
mapserver-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20171012/f4fd10bc/attachment.html>
