[mapserver-users] msOGRFileOpen(): Falling back to MapServer only evaluation
Lime, Steve D (MNIT)
steve.lime at state.mn.us
Tue Oct 17 11:50:07 PDT 2017
Hi: The message is specific to SQLite. I believe it has to do how filtering can be done and depends on the form of your DATA statement. If you don't use SQL syntax for the data statement then you have to fall back to MapServer filter syntax. See http://mapserver.org/input/vector/sqlite.html for examples of each. You could try the SQL syntax in your mapfile and see if that log entry disappears (I'm not setup to test SQLite here). Probably could make the docs clearer about the advantages of one approach vs the other. In any case I think the message is benign and informational only...
Steve
-----Original Message-----
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Gert Cuykens
Sent: Sunday, October 15, 2017 9:32 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] msOGRFileOpen(): Falling back to MapServer only evaluation
Image that i get back from the server looks good but don't understand
what the errors mean in the mapserver logs?
http://localhost:8080/?map=/basemap/basemap.map&layers=nodes&mode=tile&tilemode=gmap&tile={x}+{y}+{z}.png
MAP
NAME "basemap"
SHAPEPATH "/basemap"
CONFIG "MS_ERRORFILE" "stderr"
UNITS dd
# UNITS METERS
EXTENT 5.684829 49.398312 6.599194 50.217793
STATUS ON
DEBUG 5
PROJECTION
"init=epsg:4326"
# "init=epsg:3857"
END
WEB
METADATA
"wms_enable_request" "*"
"wms_title" "basemap"
"wms_onlineresource" "http://localhost:8080/?map=/basemap/basemap.map"
"wms_srs" "EPSG:4326"
# "wms_srs" "EPSG:3857"
"wms_format" "image/png"
# "tile_map_edge_buffer" "10"
# "tile_metatile_level" "0"
END
END
OUTPUTFORMAT
NAME "AGGPNG"
DRIVER "AGG/PNG"
EXTENSION "png"
MIMETYPE "image/png"
IMAGEMODE RGBA
END
SYMBOL
NAME "circle"
TYPE ellipse
POINTS
1 1
END
END
LAYER
NAME nodes
TYPE point
CONNECTIONTYPE OGR
CONNECTION "basemap.sqlite"
DATA nodes
CLASS
NAME "nodes"
STYLE
SYMBOL "circle"
COLOR 0 0 0
SIZE 3
END
END
END
LAYER
NAME segments
TYPE line
CONNECTIONTYPE OGR
DATA segments
CLASS
NAME "segments"
STYLE
COLOR 0 0 0
END
END
END
LAYER
NAME links
TYPE line
CONNECTIONTYPE OGR
DATA links
CLASS
NAME "links"
STYLE
COLOR 0 0 0
END
END
END
END
2017/10/16 02:25:55 [error] 11#0: *534 FastCGI sent in stderr: "CGI
Request 5 on process 9
msTileSetExtent(): gmaps coords (x: 8473, y: 5568, z: 14)
msTileSetExtent(): gmaps metacoords (x: 8473, y: 5568, z: 14)
msTileSetExtent(): base image size (256 x 256)
msTileSetExtent(): buffered image size (256 x 256)
msTileSetExtent (687326.535559, 6415823.182566) (689762.965835, 6418259.612842)
msTileSetExt" while reading response header from upstream, client:
172.17.0.1, server: , request: "GET
/?map=/basemap/basemap.map&layers=nodes&mode=tile&tilemode=gmap&tile=8473+5568+14.png
HTTP/1.1", upstream: "fastcgi://unix:/var/run/mapserv.socket:", host:
"localhost:8080"
2017/10/16 02:25:55 [error] 11#0: *534 FastCGI sent in stderr: "ent():
msDrawMap(): rendering using outputformat named AGGPNG (AGG/PNG).
msDrawMap(): WMS/WFS set-up and query, 0.000s
msDrawMap(): Layer 0 (nodes), 0.036s
msDrawMap(): Drawing Label Cache, 0.000s
msDrawMap() total time: 0.036s
msSaveImage(stdout) total time: 0.003s
mapserv request processing time (msLoadMap not incl.): 0.039s
msFr" while reading upstream, client: 172.17.0.1, server: , request:
"GET /?map=/basemap/basemap.map&layers=nodes&mode=tile&tilemode=gmap&tile=8473+5568+14.png
"localhost:8080"
"eeMap(): freeing map at 0x55f140fcb5c0" while reading upstream,
client: 172.17.0.1, server: , request: "GET
"localhost:8080"
172.17.0.1 - - [16/Oct/2017:02:25:55 +0000] "GET
HTTP/1.1" 200 9138 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X
10_12_6) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/62.0.3202.52
Safari/537.36"
172.17.0.1 - - [16/Oct/2017:02:25:55 +0000] "GET /favicon.ico
HTTP/1.1" 200 75
"http://localhost:8080/?map=/basemap/basemap.map&layers=nodes&mode=tile&tilemode=gmap&tile=8473+5568+14.png"
"Mozilla/5.0 (Macintosh; Intel Mac OS X 10_12_6) AppleWebKit/537.36
(KHTML, like Gecko) Chrome/62.0.3202.52 Safari/537.36"
mapserver-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapserver-users
