[mapserver-users] Apply style to geojson based on property in geojson data
Tuffa
chris at wherryengineering.co.uk
Tue Oct 24 07:43:06 PDT 2017
Hello!
I am rendering a map of African countries from a single geojson file. Each
country is represented as a feature with geometry. I've added a custom
value to each feature's properties, that I would like to influence the style
selected by MapServer to render the country outline, however I cannot see
how it is possible to configure the layer so that MapServer uses the new
'value' property as the input for the style expressions that I have
created...
Doing the same job, using a database as the datasource is easy! I simply
craft a SQL 'select' statement for the mapfile's Layer 'DATA' to retrieve
the desired value and it becomes available to MapServer using the
'[value_name]' syntax in style expressions.
This same approach does not appear to work for GeoJSON. MapServer states
that the extent of support for the 'DATA' is driver-dependant, which is fair
enough; examination of the geoJson driver doc in the GDAL doc's does not
help me though.
Can anyone help?
Regards
Chris
Sent from: http://osgeo-org.1560.x6.nabble.com/Mapserver-User-f4226646.html
