[mapserver-users] Apply style to geojson based on property in geojson data
Tuffa
chris at wherryengineering.co.uk
Wed Oct 25 01:08:20 PDT 2017
Hello Richard!
> I haven't used geojson as a data source, but maybe if you shared a small
> example of your map file and the data it would help.
Here's some more information....
mapfile.map (excerpt):
LAYER
NAME "countries"
STATUS OFF
TYPE POLYGON
CONNECTIONTYPE OGR
CONNECTION "africa.geojson"
DATA "select * from africa"
CLASS STYLE OUTLINECOLOR "#ff0000" END END
CLASS EXPRESSION ([value] >= 0 AND [value] <= 1000000) STYLE COLOR
"#FFE397" END END
END
I have tried numerous types of select statement in the DATA definition, but
have failed to influence the styling based on the ‘value’ property added to
the geojson file. Of course, this may have all been in vain, if the GDAL
driver does not support anything other than ‘select * from <layer>’, but I
cannot tell from the documentation - MapServer, or GDAL - what is allowed.
Here is an excerpt of the africa.geojson file, with the additional property
‘value’ added. Following is the output from ogrinfo.
"features": [
"geometry": {
"coordinates": [
8.621624,
36.941797
8.621624,
36.941797
"type": "MultiPolygon"
"properties": {
"cartodb_id": 1,
"created_at": "2013-11-12T16:15:59+0100",
"name": "Algeria",
"updated_at": "2013-11-12T16:15:59+0100",
"value": 10000 <<<<<<<<<<<<<<<<<<<<<<<<<<<< custom
property
"type": "Feature"
"type": "FeatureCollection"
chris:tmp chris$ ogrinfo -summary -al africa.geojson
INFO: Open of `africa.geojson'
using driver `GeoJSON' successful.
Layer name: africa
Geometry: Multi Polygon
Feature Count: 1
Extent: (8.621624, 36.941797) - (8.621624, 36.941797)
Layer SRS WKT:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4326"]]
value: Integer (0.0) <<<<<<<<<<<<<<<<<<<<<<<< here’s the additional
property
cartodb_id: Integer (0.0)
created_at: DateTime (0.0)
updated_at: DateTime (0.0)
Sent from: http://osgeo-org.1560.x6.nabble.com/Mapserver-User-f4226646.html
