[mapserver-users] Rewrite rule problem
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu Oct 26 11:22:41 PDT 2017
Hi Goran,
Regarding have a cleaner WMS url inside your MS4W installation, you can
follow the steps at
http://mapserver.org/ogc/wms_server.html#changing-the-online-resource-url
So that means, if you wanted a clean url like
http://localhost/cgi-bin/Demo/wms? you could:
- rename /ms4w/Apache/cgi-bin/mapserv.exe to /ms4w/Apache/cgi-bin/wms
(no extension)
- edit /ms4w/Apache/conf/httpd.conf and add at the bottom something like
SetEnvIf Request_URI "/cgi-bin/wms" MS_MAPFILE=C:/ms4w/apps/mymap.map
- restart Apache service
apache-restart.bat
Hope that helps.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2017-10-21 4:31 AM, gorank wrote:
> I would like to use Rewrite rules to change path to the map file in the URL
> with mapfile name only.
> Example:
> http://localhost:81/cgi-bin/Demo/wms?map=*/ms4w/apps/Demo/N1.map*&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.3.0
> for users to be
> http://localhost:81/cgi-bin/Demo/wms?map=*N1.map*&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.3.0
> I have tried different sugestions in mapserver documenation but it doesn't
> work.
> I need help somebody to describe step by step:
> 1. Where should be located the new created .htaccess file (Rewrite mode in
> the httpd.conf file is activated - without #) . In the httpd.conf file
> Document Root is
> # DocumentRoot: The directory out of which you will serve your
> # documents. By default, all requests are taken from this
> directory, but
> # symbolic links and aliases may be used to point to other
> locations.
> DocumentRoot "C:/ms4w/Apache/htdocs"
> AccessFileName .htaccess
> 2. What should be written in the .htaccess file in my case
> 3. If i have different Rewrite rules for different paths how to separate
> them in the .htaccess file
> Best Regards,
> Goran
