[mapserver-users] problem with mapserver as wms client
Susanne Kalliany
susanne.kalliany at tefis.at
Fri Sep 1 15:05:39 PDT 2017
I have some problems adding a WMTS layer from an Austrian goverment
server ...
https://basemap.at OR
https://basemap.at/index_en.html
... into an (yet for years !) reliable running mapserver-service.
I am able to import the layer(s) offered there (various Versions of OSM
and Austrian topo maps an - most of all - Orthophotos for whole of Austria
at 20 cm GSD resolution) from basemap.at into openlayers.
But I need to provide those data right now to my users !
That is already before I will be able to replace the current Mapserver
installation by a totally renewed version (with OpenLayers integrated).
Thereforefore, right now I would need the appropriate WMTS-call
intgrated in the current mapfile.
I am pretty desperate, any help would be MUCH appreciated !
thanks a lot,
Susanne
> MAP-File
> MAP
> NAME mymap
> STATUS ON
> SIZE 1000 1000
> PROJECTION
> "init=epsg:3857"
> END
> EXTENT 1673000 6024000 1683000 6034000
> WEB
> IMAGEPATH "/ms4w/tmp/ms_tmp/"
> IMAGEURL "/ms_tmp/"
> METADATA
> "wms_title" "TEST"
> "wms_onlineresource" "http://localhost/cgi-bin/mapserv?"
> "wms_srs" "EPSG:3857"
> "wms_enable_request" "*"
> END
> END
> DEBUG 5
> CONFIG "MS_ERRORFILE" "/ms4w/Apache/logs/myerror.log"
> LAYER
> NAME "bmaporthofoto30cm"
> TYPE RASTER
> DEBUG 5
> STATUS ON
> TEMPLATE "dummy.html"
> UNITS METERS
> CONNECTIONTYPE WMS
> CONNECTION
> "https://maps.wien.gv.at/basemap/1.0.0/WMTSCapabilities.xml"
> METADATA
> WMS_NAME 'bmaporthofoto30cm'
> wms_srs "EPSG:3857"
> wms_server_version "1.0.0"
> wms_format "image/jpeg"
> END #Metadata
> PROJECTION
> "init=epsg:3857"
> END
> END # LAYER
> END
> Error
> [Fri Aug 25 03:53:50 2017].757000 msLoadMap(): 0.000s
> [Fri Aug 25 03:53:50 2017].772000 msDrawMap(): rendering using
> outputformat named png (AGG/PNG).
> [Fri Aug 25 03:53:50 2017].772000 HTTP: Starting to prepare HTTP
> requests.
> [Fri Aug 25 03:53:50 2017].772000 Using
> CURL_CA_BUNDLE=/ms4w/Apache/conf/ca-bundle/cacert.pem
> [Fri Aug 25 03:53:50 2017].772000 HTTP request: id=0,
> https://maps.wien.gv.at/basemap/1.0.0/WMTSCapabilities.xml?LAYERS=bmaporthofoto30cm&REQUEST=map&WMTVER=1.0.0&SERVICE=WMS&FORMAT=image/jpeg&STYLES=&HEIGHT=1200&QUERY_LAYERS=bmaporthofoto30cm&SRS=EPSG:3857&WIDTH=1600&BBOX=1671327.77314429,6023995.82985822,1684672.22685571,6034004.17014178&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_xml
> [Fri Aug 25 03:53:50 2017].772000 HTTP: Before download loop
> [Fri Aug 25 03:53:52 2017].7000 msHTTPWriteFct(id=0, 8131 bytes)
> [Fri Aug 25 03:53:52 2017].7000 msHTTPWriteFct(id=0, 61 bytes)
> [Fri Aug 25 03:53:52 2017].85000 msHTTPWriteFct(id=0, 7300 bytes)
> [Fri Aug 25 03:53:52 2017].85000 msHTTPWriteFct(id=0, 892 bytes)
> [Fri Aug 25 03:53:52 2017].85000 msHTTPWriteFct(id=0, 4228 bytes)
> [Fri Aug 25 03:53:52 2017].85000 HTTP: After download loop
> [Fri Aug 25 03:53:52 2017].85000 msHTTPExecuteRequests() timing
> summary per layer (connect_time + time_to_first_packet + download_time
> = total_time in seconds)
> [Fri Aug 25 03:53:52 2017].85000 Layer 0: 0.094 + 1.141 + 0.172 =
> 1.407s
> [Fri Aug 25 03:53:52 2017].85000 msDrawMap(): WMS/WFS set-up and
> query, 1.313s
> [Fri Aug 25 03:53:52 2017].85000 WMS GetMap request got XML exception
> for layer 'bmaporthofoto30cm': <?xml version="1.0" encoding="UTF-8"?>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170901/9248a6c4/attachment.html>
