[mapserver-users] Compiling RSVG in 7.2
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Aug 22 14:53:22 PDT 2018
I've had success with libsvg + libsvg-cairo on systems, I recommend
giving that a try. -jeff
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
On 2018-08-22 1:47 PM, public at postholer.com wrote:
> Greetings,
> I'm trying to compile 7.2 with RSVG support with zero luck. Can someone point out my mistake? OS is CentOS 6.5.
> Here's all the relevant info:
> cmake output. cmake command and full response is at the bottom:
> -- Could NOT find GOBJECT (missing: GOBJECT_INCLUDE_DIR)
> CMake Error at CMakeLists.txt:69 (message):
> RSVG library/component/dependency could not be found.
> HINTS:
> - disable RSVG support by adding -DWITH_RSVG=0
> - add the RSVG install directory to the CMAKE_PREFIX_PATH variable (-DCMAKE_PREFIX_PATH="/path/to/RSVG-install-dir;/path/to/other/dirs"
> Call Stack (most recent call first):
> CMakeLists.txt:630 (report_optional_not_found)
