[mapserver-users] Problem with WMS time (filter do not works)
Roberto Marzocchi
roberto.marzocchi at gter.it
Fri Aug 24 06:23:59 PDT 2018
No I use a mapfile where I have defined the time index layer and the raster layer. http://demo.gter.it/cgi-bin/mapserv?map=/home/rasdaman/bui_mapfile_test.map& An example of my request is http://demo.gter.it/cgi-bin/mapserv?map=/home/rasdaman/bui_mapfile_test.map&LAYERS=bui_20180101&TRANSPARENT=TRUE&FORMAT=image%2Fpng&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3A3003&BBOX=1436300.0000000000000000,4916700.0000000000000000,1701800.0000000000000000,5177700.0000000000000000&WIDTH=1088&HEIGHT=621 R ---- On ven, 24 ago 2018 15:04:57 +0200 Seth G <sethg at geographika.co.uk> wrote ---- How are you accessing the service? Do you have an example URL? Are you setting the TIME parameter as part of this? https://mapserver.org/ogc/wcs_server.html#test-with-a-getcoverage-request http://my.host.com/cgi-bin/mapserv?map=mywcs.map&SERVICE=WCS &VERSION=1.0.0&REQUEST=GetCoverage&coverage=bathymetry &CRS=EPSG:42304&TIME=2018-01-01T00:00:00&WIDTH=3199 &HEIGHT=2833&FORMAT=GTiff -- web:http://geographika.co.uk twitter: @geographika On Fri, Aug 24, 2018, at 2:56 PM, Roberto Marzocchi wrote: Thanks for your answer.. I try your suggestion using " instead of ' (otherwise I have a parsing error) but unfortunately no difference (the filter is "ignored" PROCESSING "NATIVE_FILTER= 'day'='2018-01-01T00:00:00'" R Eng. Roberto Marzocchi, PhD
GIS Project Coordinator
Gter srl (Unige spin-off)
Piazza De Marini 3/61 - 16123 Genova
P.IVA/CF 01998770992
ph: 010-8694830 - mob: 349-8786575
E-mail: roberto.marzocchi at gter.it
skype: roberto.marzocchi84
www.gter.it
Gter social
www.twitter.com/Gteronline - www.facebook.com/Gteronline - https://plus.google.com/+GterIt/posts
www.linkedin.com/company/gter-srl-innovazione-in-geomatica-gnss-e-gis
Please consider the environment before printing this email! ---- On ven, 24 ago 2018 14:37:00 +0200 Seth G <sethg at geographika.co.uk> wrote ---- Hi, Is there any difference if you use a native filter? E.g. PROCESSING 'NATIVE_FILTER=day= '2018-01-01T00:00:00'' Seth -- web:http://geographika.co.uk twitter: @geographika On Fri, Aug 24, 2018, at 2:14 PM, Roberto Marzocchi wrote: Dear all, i have done more test if I uncomment the "wms_timedefault" "2018-01-01T00:00:00" line it give me the following error: msWMSApplyTime: WMS server error. No Time value was given, and no default time value defined. otherwise it give me no error but my WMS use always the last line of the postgis table not considering the FILTER. I try a lot of fiter syntaxes. my raster layer definition is the following: # raster layer LAYER NAME "bui_20180101" TYPE RASTER STATUS ON DEBUG ON PROJECTION "init=epsg:3003" END METADATA "wms_title" "bui_20180101" "wms_srs" "EPSG:3003" "wms_extent" "1436301.37500 4916704.50000 1701801.37500 5177704.50000" "wms_timeextent" "2017-08-01/2100-12-31/PT24H" "wms_timeitem" "day" #datetime is a column in postgis table of type timestamp #"wms_timedefault" "2018-01-01T00:00:00" "wms_enable_request" "*" "ows_include_items" "all" END OFFSITE 0 0 0 TILEITEM "location" #filepath is a column in postgis table with varchar of the filepath to each image TILEINDEX "time_idx" #FILTERITEM "day" #FILTER "2018-01-01T00:00:00" #FILTER (`[day]` = `2018-01-01T00:00:00`) #FILTER ('[day]' = '2018-01-01T00:00:00') FILTER ("day" = '2018-01-01T00:00:00') END Thanks in advanced for your help. R Eng. Roberto Marzocchi, PhD
www.gter.it
Gter social
Please consider the environment before printing this email! ---- On mar, 21 ago 2018 13:26:23 +0200 Roberto Marzocchi <roberto.marzocchi at gter.it> wrote ---- Dear all, I am following the guide to create WMS/WCS time [1]. (Mapserver 7.0.7 on Ubuntu Xenìal server) I created a PostGIS view with the following field: - id - location - day - geom I create a mapfile but when I create the layer the filter do not works (I see always the last row e.g the map of yesterday). I try: FILTERITEM "day" FILTER "20180101" and FILTER (`[day]` = `20180101`) like in the example I try to change the day format in the PostGIS table from text to timestamp (e.g20180101 --> 2018-01-01 00:00:00) but nothing change. There is something not clear to me. R [1] - https://mapserver.org/ogc/wms_time.html#example-of-wms-t-with-postgis-tile-index-for-raster-imagery Eng. Roberto Marzocchi, PhD
www.gter.it
Gter social
Please consider the environment before printing this email! _______________________________________________ mapserver-users mailing list mapserver-users at lists.osgeo.org https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20180824/8b1b8f27/attachment.html>
