[mapserver-users] scaletoken data or tileindex
Travis Kirstine
traviskirstine at gmail.com
Tue Aug 28 06:10:57 PDT 2018
I'm trying to use the scaletoken with a raster layer that is represented by
a combination of full resolution tiles (tileindex) and a stack of merged
lower resolution geotiffs. Is is possible to use the scaletoken to use a
combination of a TILEINDEX and DATA to call the source data? From the
error log it appears to expect one or the other (DATA or TILEINDEX)
LAYER
NAME spot_z16
METADATA
wms_title "Zone 16 Spot"
wms_extent "275997 5109997 732003 6304003"
END
TYPE RASTER
PROCESSING "RESAMPLE=BILINEAR"
OFFSITE 0 0 0
PROJECTION
"init=epsg:26916"
END
SCALETOKEN
NAME "%pri%"
VALUES
"0" "spot_z16_rgb_2km_tindex"
"100000" "z16_rgb_24m_mosaic"
"800000" "z16_rgb_192m_mosaic"
END
END
TILEINDEX "/maps/spot_tindex/%pri%"
DATA "/maps/spot_overalls/%pri%.tif"
END
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20180828/4f919674/attachment.html>
