[mapserver-users] How use ogr provider with spatialite "read only" clause
Yves Jacolin
yves.jacolin at camptocamp.com
Wed Jan 10 03:33:10 PST 2018
Hello Andrea,
Can't you do that by "chmod" the file?
Y.
2018-01-10 12:28 GMT+01:00 Andrea Peri <aperi2007 at gmail.com>:
> Hi,
> Usually we use the spatialite db as ordinary datasource for ours mapserver
> wms.
> Now I discovered that the last versions of spatialite always test
> automatically the version of the DB sqlite and if verify that the db was
> create using an older spatialite version.
> TRY TO UPDATE the spatialite system tables WHEN the connection was closed.
> This probably is a good strategy for an ordinary desktop application.
> But more risk pendent when used on a mpaserver that could have more than
> one connection open on the same DB sqlite.
> To avoid this the standard solution used from the spatialite driver is to
> check if the DB is open in READ-ONLY mode.
> And avoid to write and update the db when it is in read-only mode.
> So my trouble now is how the change the usual connection string in the
> mapfile to say to the OGR driver to open the sqlite/spatialite using the
> "read-only" mode.
> Is this possible ?
> Many thx
> A.
> Andrea Peri
> qwerty àèìòù
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
Training and support manager
Camptocamp France SAS
Bâtiment le Dauphin - 1er étage
18 rue du Lac Saint André
73382 Le Bourget-du Lac
Tel (France) : +33 4 58 48 20 43
Tel (Switzerland) : +41 21 619 10 43
Mob. : +33 6 18 75 42 21
email : yves.jacolin at camptocamp.com
http://www.camptocamp.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20180110/718051a9/attachment.html>
