[mapserver-users] MapServer returns a blank image when requesting a square image
Pablo Sanfilippo
sanfilippopablo at gmail.com
Wed Jan 10 09:46:34 PST 2018
Hi all,
I admit this is the weirdest issue I have come across. This are the
relevant parts of my MapServer configuration:
# A valid mapfile used for testing
MAP
NAME valid
STATUS ON
PROJECTION
"init=epsg:4326"
END
IMAGECOLOR 0 0 0
TRANSPARENT ON
WEB
METADATA
"wms_srs" "EPSG:4326 EPSG:3857"
END
END
LAYER
NAME "index"
STATUS ON
TYPE POLYGON
CONNECTIONTYPE POSTGIS
CONNECTION "host=x port=x dbname=x user=x password=x"
DATA "geometry from (select i.geometry, i.id, '/vsis3/' || i.s3_bucket
|| '/' || i.s3_key as location from images_image) as index using unique id"
CLASS
STYLE
OUTLINECOLOR 0 0 0
WIDTH 1.0
COLOR 200 200 200
ANTIALIAS true
END
END
END
LAYER
NAME "images"
STATUS ON
TILEINDEX "index"
TILEITEM "location"
TYPE RASTER
PROJECTION
AUTO
END
METADATA
"wms_title" "Images"
END
END
END
The data in the PostGIS index is in EPSG:4326. The images referenced by the
index are GeoTIFFs georeferenced in EPSG:4326.
A WMS request for the index layer shows the index polygons fine, whatever
the SRS and image size in the request.
A WMS request for the images layer using SRS=EPSG:4326 shows the images
fine, whatever the image size.
A WMS request for the images layer using SRS=EPSG:3857 will work fine as
long as the requested image size's x is greater than or equal to the y. If
not, it will return a blank (transparent) image. For example, a 1300x1299
image will work fine, a 1300x1300 image won't work and 1301x1300 won't work
either.
Any clues?
Thanks!
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20180110/8809defc/attachment-0001.html>
