[mapserver-users] MapServer returns a blank image when requesting a square image
Pablo Sanfilippo
sanfilippopablo at gmail.com
Thu Jan 11 07:46:48 PST 2018
I'm going to try and make that zip.
About explicit PROJECTION blocks, actually yes. I forgot about mentioning
that. It works fine when explicitly setting the PROJECTION in the raster
layer. However, I can't do that because the files referenced by the
tileindex are in different projections.
On Thu, Jan 11, 2018 at 11:00 AM, Rahkonen Jukka (MML) <
jukka.rahkonen at maanmittauslaitos.fi> wrote:
> Hi,
> I have been using a spatialite layer as a tileindex for years without
> problems so definitely that is not a bug that affects all users and use
> cases. Try to create a zip file that contains everything that is needed for
> reproducing the issue. Let’s hope that you can make it with a spatialite
> database and two images in the tileindex.
> Have you already tried to add explicit PROJECTION blocks into both LAYERs?
> -Jukka Rahkonen-
> *Lähettäjä:* mapserver-users [mailto:mapserver-users-
> bounces at lists.osgeo.org] *Puolesta *Pablo Sanfilippo
> *Lähetetty:* 11. tammikuuta 2018 14:46
> *Vastaanottaja:* Seth G <sethg at geographika.co.uk>
> *Kopio:* mapserver-users at lists.osgeo.org
> *Aihe:* Re: [mapserver-users] MapServer returns a blank image when
> Oh, so this is a definitely a bug. Is it reported yet in the issue tracker?
> On Wed, Jan 10, 2018 at 3:55 PM, Seth G <sethg at geographika.co.uk> wrote:
> Hi Pablo,
> Just to note I also ran into this issue so you are not alone!
> A WMS request from OpenLayers to MapServer would be fine, but modifying
> the size of the image (WIDTH and HEIGHT parameters) would result in a blank
> image and no errors in the logs.
> I never got a chance to debug further though. An error should ideally be
> reported somewhere rather than a blank, seemingly valid, image.
> Seth
> web:http://geographika.co.uk
> twitter: @geographika
> On Wed, Jan 10, 2018, at 6:46 PM, Pablo Sanfilippo wrote:
> Hi all,
> I admit this is the weirdest issue I have come across. This are the
> relevant parts of my MapServer configuration:
> # A valid mapfile used for testing
> MAP
> NAME valid
> STATUS ON
> PROJECTION
> "init=epsg:4326"
> END
> IMAGECOLOR 0 0 0
> TRANSPARENT ON
> WEB
> METADATA
> "wms_srs" "EPSG:4326 EPSG:3857"
> END
> END
> LAYER
> NAME "index"
> STATUS ON
> TYPE POLYGON
> CONNECTIONTYPE POSTGIS
> CONNECTION "host=x port=x dbname=x user=x password=x"
> DATA "geometry from (select i.geometry, i.id, '/vsis3/' ||
> i.s3_bucket || '/' || i.s3_key as location from images_image) as index
> using unique id"
> CLASS
> STYLE
> OUTLINECOLOR 0 0 0
> WIDTH 1.0
> COLOR 200 200 200
> ANTIALIAS true
> END
> END
> END
> LAYER
> NAME "images"
> STATUS ON
> TILEINDEX "index"
> TILEITEM "location"
> TYPE RASTER
> PROJECTION
> AUTO
> END
> METADATA
> "wms_title" "Images"
> END
> END
> END
> The data in the PostGIS index is in EPSG:4326. The images referenced by
> the index are GeoTIFFs georeferenced in EPSG:4326.
> A WMS request for the index layer shows the index polygons fine, whatever
> the SRS and image size in the request.
> A WMS request for the images layer using SRS=EPSG:4326 shows the images
> fine, whatever the image size.
> A WMS request for the images layer using SRS=EPSG:3857 will work fine as
> long as the requested image size's x is greater than or equal to the y. If
> not, it will return a blank (transparent) image. For example, a 1300x1299
> image will work fine, a 1300x1300 image won't work and 1301x1300 won't work
> either.
> Any clues?
> Thanks!
> *_______________________________________________*
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20180111/36596d54/attachment.html>
