[mapserver-users] Is it possible to isolate mapserver on docker?
Antti J. Lind anttij.lind at birdlife.fi
Sun Jul 1 10:38:01 PDT 2018
Hi and thank's,
But how to use Apache's redirect with php-mapscript?
AJL
Humberto Cereser Ibanez kirjoitti 2018-06-30 19:14:
> ...but then you would proxy that out to your external http server.
> I'm using Apache2 Redirect:
> Redirect /example http://172.17.0.3/example
> on vhost who is also a container in the same host.
> 172.17.0.3 is the ip of the container with Apache2 and Mapserver
> 2018-06-30 11:32 GMT-03:00 Michael Smith
> <michael.smith.erdc at gmail.com>:
>> You can certainly run mapserver via cgi standalone on docker but if
>> you want to do php mapscript, you’d need mapserver compiled with
>> php mapscript in the docker container. If you do that, you’d
>> probably need a http server inside the container but then you would
>> Michael Smith
>>> On Jun 30, 2018, at 9:59 AM, Antti J. Lind
>> <anttij.lind at birdlife.fi> wrote:
>>> Hello list,
>>> We are currently using php-mapserver-apache on centos7.
>>> Now there is one wms-server, which is using wms server version
>> 1.3.0 and our mapservers client does not.
>>> It seems to be quite big change to update our current version 6.2
>> to 7.2 beta and run it on same host as php-scripts and apache.
>>> It there some way to isolate mapserver on docker or run it on
>> another host without http-server?
>>> On docker hub there is only images, which are including
>> http-server with mapserver.
>>> Antti J. Lind
>>> BirdLife Finland
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/mapserver-users [1]
> Links:
> [1] https://lists.osgeo.org/mailman/listinfo/mapserver-users
