[mapserver-users] Wrong case of "TileOutOfRange" Error?
thomas bonfort thomas.bonfort at gmail.com
Fri Jun 22 01:12:45 PDT 2018
here is how the y=5 you are seeing is calculated:
https://github.com/mapserver/mapcache/blob/master/lib/service_wmts.c#L830
On Fri, Jun 22, 2018 at 9:05 AM Julian Hollingbery <julian at northtech.dk>
wrote:
> Hi Ian and Jukka,
> Thanks for your response!
> However, I’m pretty sure that the TileMatrix-parameter is good, since this
> works nicely:
> &TILEMATRIXSET=GSTutm32&TILEMATRIX=5&TILEROW=39&TILECOL=64&FORMAT=image%2Fpng
> (TileRow changed from 40 to 39).
> After all, I copied the request from
> http://xx.xx.xx.xx/servicename/demo/wmts, which, incidentally, shows the
> infamous pink tiles, if I pan to the outer edges of the tilegrid.
> Regards,
> /julian
> *Fra:* Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>
> *Sendt:* 21. juni 2018 17:58
> *Til:* Ian Turton <ijturton at gmail.com>; Julian Hollingbery <
> *Cc:* mapserver-users at lists.osgeo.org
> *Emne:* Re: [mapserver-users] Wrong case of "TileOutOfRange" Error?
> Hi,
> I don’t see a relevant part of GetCapabilities but I believe that the name
> of the tile matrix in MapCache based WMTS services is plain ”5” like here
> https://avoin-karttakuva.maanmittauslaitos.fi/avoin/wmts/1.0.0/WMTSCapabilities.xml
> GetTile example
> https://avoin-karttakuva.maanmittauslaitos.fi/avoin/wmts?service=WMTS&request=GetTile&version=1.0.0&layer=maastokartta&style=default&format=image/png&TileMatrixSet=ETRS-TM35FIN&TileMatrix=6&TileRow=44&TileCol=27
> -Jukka Rahkonen-
> *Lähettäjä:* mapserver-users [
> mailto:mapserver-users-bounces at lists.osgeo.org
> <mapserver-users-bounces at lists.osgeo.org>] *Puolesta *Ian Turton
> *Lähetetty:* 21. kesäkuuta 2018 17:12
> *Vastaanottaja:* Julian Hollingbery <julian at northtech.dk>
> *Kopio:* mapserver-users at lists.osgeo.org
> *Aihe:* Re: [mapserver-users] Wrong case of "TileOutOfRange" Error?
> It looks like MapServer is mixing up tileset and tilerow (probably a cut
> and paste error in the error message) - I think the tile matrix should
> be GSTutm32:5 not just 5.
> Ian
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20180622/8317c484/attachment-0001.html>
