[mapserver-users] time enabled WCS with tile index
Rousseau Lambert2, Louis-Philippe (EC)
louis-philippe.rousseaulambert2 at canada.ca
Thu Jun 28 06:20:04 PDT 2018
Hi guys,
I'm working on a project which requires WMS and WCS time enabled layers.
I'm using the tile index for time support, which is working fine for WMS but I can't get the time to work for WCS request...
In my shapefile I have a column for the data path and one (timestamp) for the time.
Exemple request form Qgis WCS:
mapserv -nh "QUERY_STRING=map=/path/to/mapfile/WCS-en.map&SERVICE=WCS&VERSION=1.0.0&REQUEST=GetCoverage&FORMAT=GTiff&COVERAGE=DCS.TN.HISTO.YEAR.ABS_PCTL25&TIME=1978&BBOX=-96.74998463567416707,62.12500003000000248,-96.2499848643258531,62.37499996999999752&CRS=EPSG:4326&RESPONSE_CRS=EPSG:4326&WIDTH=6&HEIGHT=3" > dcs.tif
I get an error:
<?xml version='1.0' encoding="UTF-8" ?> <ServiceExceptionReport version="1.2.0" xmlns="http://www.opengis.net/ogc" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/ogc http://schemas.o
pengis.net/wcs/1.0.0/OGC-exception.xsd">
<ServiceException>msGetGDALBandList(): Image handling error. BANDS PROCESSING directive has wrong number of bands, expected at most 4, got 55.
</ServiceException>
</ServiceExceptionReport>
At the base I have one netcdf file with 55 bands each representing a different time step. In order to use the shapefile index, I created 55 VRTs each pointing to a band in the original NetCDF. Than in the shapefile index, I'm pointing to those VRT for each time step. It works fine for WMS but not WCS...
Here is my mapfile:
MAP
STATUS ON
WEB
METADATA
"wcs_description" "The weather can have an incredible influence on our daily lives. It affects the growth of crops and the availability of water. It dictates which regions of the world are habitable or uninhabitable"
"ows_extent" "-141,42,-52,84"
"ows_contactinstructions" "During hours of service"
"wcs_label" "Meteorological Service of Canada Geospatial Web Services 0.1.0"
"ows_title" "title"
"wcs_enable_request" "*"
END
END
PROJECTION
"init=epsg:4326"
END
NAME "climate"
QUERYMAP
STATUS OFF
COLOR 255 255 0
STYLE HILITE
SIZE 500 300
END
LAYER
STATUS OFF
NAME "DCS.TN.HISTO.YEAR.ABS_PCTL25-tileindex"
DATA "/path/to/tileindex/ts_absolute_p25_historical_1951_2005_tn_ann.shp"
TYPE POLYGON
FILTERITEM 'timestamp'
FILTER '%timestamp%'
METADATA
"ows_enable_request" "!*"
END
END
LAYER
STATUS ON
TILEITEM "location"
NAME "DCS.TN.HISTO.YEAR.ABS_PCTL25"
DUMP TRUE
TILEINDEX "DCS.TN.HISTO.YEAR.ABS_PCTL25-tileindex"
CLASS
GROUP "TEMP-ABSOLUTE"
STYLE
DATARANGE -60 -28
COLORRANGE 10 40 100 51 102 217
END
EXPRESSION ([pixel] < -28 AND [pixel] > -95)
NAME "< -28"
END
TEMPLATE "ttt.html"
CLASSGROUP "TEMP-ABSOLUTE"
METADATA
"ows_timeextent" "1951/2005/P1Y"
"wcs_timeposition" '1951,1952,1953,1954,1955,1956,1957,1958,1959,1960,1961,1962,1963,1964,1965,1966,1967,1968,1969,1970,1971,1972,1973,1974,1975,1976,1977,1978,1979,1980,1981,1982,1983,1984,1985,1986,1987,1988,1989,1990,1991,1992,1993,1994,1995,1996,1997,1998,1999,2000,2001,2002,2003,2004,2005'
"wcs_band_names" "B1951 B1952 B1953 B1954 B1955 B1956 B1957 B1958 B1959 B1960 B1961 B1962 B1963 B1964 B1965 B1966 B1967 B1968 B1969 B1970 B1971 B1972 B1973 B1974 B1975 B1976 B1977 B1978 B1979 B1980 B1981 B1982 B1983 B1984 B1985 B1986 B1987 B1988 B1989 B1990 B1991 B1992 B1993 B1994 B1995 B1996 B1997 B1998 B1999 B2000 B2001 B2002 B2003 B2004 B2005"
"wms_timeitem" "timestamp"
"wcs_timeitem" "timestamp"
"ows_extent" "-140.9999644 41.0000051 -52.0000051 83.4999949"
"ows_title" "title"
"wms_timedefault" "2005"
"ows_enable_request" "*"
"ows_layer_group" "//Downscale climate scenarios (DCS)/Maximum temperature/Historical/Annual"
"wcs_label" "Mean temperature"
"wcs_resolution" "0.083333295198278 -0.083333313348017"
"wcs_size" "1068 510"
"wcs_bandcount" "55"
END
TYPE RASTER
PROJECTION
"+proj=longlat +datum=WGS84 +no_defs "
END
END
IMAGECOLOR 255 255 255
MAXSIZE 4096
OUTPUTFORMAT
MIMETYPE "image/tiff"
NAME "GEOTIFF_32"
EXTENSION "tif"
DRIVER "GDAL/GTiff"
IMAGEMODE FLOAT32
END
END
EXTENT -141 42 -52 84
DEBUG OFF
TRANSPARENT ON
IMAGETYPE "PNG"
SIZE 500 300
END
Thanks for the help!
LP
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20180628/574b4c9c/attachment.html>
