[mapserver-users] MapServer and Geopackage failing
Gert Cuykens gert.cuykens at gmail.com
Tue Mar 6 07:31:54 PST 2018
Having the same error message but I thought it was because of gdal not
compiled with spatialite or something?
gdal = https://pkgs.alpinelinux.org/package/edge/testing/x86/gdal-dev
2018/03/02 13:18:21 [error] 15#0: *1 FastCGI sent in stderr: "CGI
Request 1 on process 10
msOGRFileOpen: Spatialite support in GPKG not enabled
msOGRFileNextShape(): OGR error. OGR GetNextFeature() error'd. Check logs.
msOGRFileNextShape(): In ExecuteSQL(): sqlite3_prepare_v2(SELECT
spatialite_version()):
  no such function: spatialite_version
PS could it be using the native shapefile/qix implementation is much
faster than any ogr driver/gpkg alternative even with spatial index
enabled ?
On Tue, Mar 6, 2018 at 12:05 PM, Seth G <sethg at geographika.co.uk> wrote:
> Thanks Even!
> I'll get a build together and test,
> Seth
> web:http://geographika.co.uk
> twitter: @geographika
> On Tue, Mar 6, 2018, at 11:41 AM, Even Rouault wrote:
> Seth,
> I've pushed a temptative fix per
> https://github.com/mapserver/mapserver/commit/4e4885f8598764b7cfb3a8c1c91c6f60eb12671f
> but I'm not completely positive this will fix what you've seen.
> Even
>> Hi all,
>> I'm trying out the geopackage format as an alternative to shapefiles but
>> running into an issue where MapServer expects the geopackage dataset to
>> include spatialite. Drawing layers with shp2img logs the following:
>> [Tue Mar 06 10:39:42 2018].512000 msDrawMap(): rendering using
>> outputformat
>> named png (AGG/PNG). [Tue Mar 06 10:39:42 2018].512000 msDrawMap():
>> WMS/WFS
>> set-up and query, 0.000s [Tue Mar 06 10:39:42 2018].529000 msOGRFileOpen:
>> Spatialite support in GPKG not enabled [Tue Mar 06 10:39:42 2018].549000
>> [Tue Mar 06 10:39:42 2018].549000 msOGRFileNextShape(): In ExecuteSQL():
>> sqlite3_prepare(SELECT spatialite_version()): no such function:
>> spatialite_version
>> [Tue Mar 06 10:39:42 2018].550000 msDrawMap(): Image handling error.
>> Failed
>> to draw layer named 'ways'.
>> The spatialite_version function is missing in the geopackage. The dataset
>> was created by exporting from MapServer as an OUTPUTOPTION:
>> OUTPUTFORMAT
>> NAME "GeoPackage"
>> DRIVER "OGR/GPKG"
>> FORMATOPTION "STORAGE=memory"
>> FORMATOPTION "FORM=simple"
>> FORMATOPTION "FILENAME=result.gpkg"
>> FORMATOPTION "DSCO:SPATIALITE=YES" # not a listed option, but tried
>> anyway FORMATOPTION "LCO:SPATIAL_INDEX=YES"
>> END
>> Running a GisInternals build, including GDAL 2.1.3 and MapServer 7.0.4.
>> Relevant code is at
>> https://github.com/mapserver/mapserver/blob/aae74ff2abed3f2f8fe1f76c9b4bbcc
>> f15023dc1/mapogr.cpp#L1313 It looks like the error should be swallowed up?
>> The same dataset exported directly to spatilite works fine.
>> Anyone experienced the above issue?
>> Regards,
>> Seth
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
> Spatialys - Geospatial professional services
> http://www.spatialys.com
