[mapserver-users] which versions for mapserver 4.8.3
Daniel Morissette
dmorissette at mapgears.com
Tue Mar 6 09:10:58 PST 2018
gdFontCacheSetup was added in GD 2.0.16 and that's what this configure
test is checking for.
Your install.log suggests that you installed GD 2.2.5 from source.
Perhaps double check to make sure that you do not have two versions of
GD on the system (one installed by the OS and one in your custom
builds), in which case the configure script could possibly pick up the
wrong version for the test. Also double check your GD build options to
make sure there is not something disabling gdFontCacheSetup in your build.
Daniel
On 2018-03-06 11:44 AM, DamienZINS wrote:
> Hi
> I translate version from SOLARIS to Centos 7.x
> [root at localhost old]# cat /etc/redhat-release
> CentOS Linux release 7.4.1708 (Core)
> my differents versions. I compile these sources
> [root at localhost old]# grep installation install.log
>>>>>>>>>>> installation de freetype-2.8 <<<<<<<<<<
>>>>>>>>>>> installation de zlib-1.2.11 <<<<<<<<<<
>>>>>>>>>>> installation de libpng-1.6.32 <<<<<<<<<<
>>>>>>>>>>> installation de proj-4.9.3 <<<<<<<<<<
>>>>>>>>>>> installation de jpegsrc.v9b <<<<<<<<<<
>>>>>>>>>>> installation de libiconv-1.15 <<<<<<<<<<
>>>>>>>>>>> installation de libgd-2.2.5 <<<<<<<<<<
>>>>>>>>>>> installation de gdal-2.2.1 <<<<<<<<<<
>>>>>>>>>>> installation de apr-1.6.2 <<<<<<<<<<
>>>>>>>>>>> installation de apr-util-1.6.0 <<<<<<<<<<
>>>>>>>>>>> installation de pcre-8.41 <<<<<<<<<<
>>>>>>>>>>> installation de httpd-2.4.27 <<<<<<<<<<
>>>>>>>>>>> installation de tomcat-connectors-1.2.42-src <<<<<<<<<<
>>>>>>>>>>> installation de php-4.4.2 <<<<<<<<<<
> checking for Oracle (OCI8) support using ORACLE_HOME installation... no
> | distribution in the file LICENSE. By continuing this installation |
> | the installation process at this point. |
>>>>>>>>>>> installation de mapserver-4.8.3 <<<<<<<<<<
> All the compilation are OK, except mapserver , the error is on
> gdFontCacheSetup
> configure:5660: checking for gdFontCacheSetup in -lgd
> configure:5690: gcc -o conftest -g -O2 -fPIC conftest.c -lgd -lpng
> -L/lib64 -lz -L -lm -lstdc++ >&5
> /tmp/ccC3N1Py.o: In function `main':
> /gmao/old/src/mapserver-4.8.3/conftest.c:24: undefined reference to
> `gdFontCacheSetup'
> collect2: error: ld returned 1 exit status
> my question is :
> is the error come from the version that i use ?
> Sent from: http://osgeo-org.1560.x6.nabble.com/Mapserver-User-f4226646.html
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
Daniel Morissette
Mapgears Inc
T: +1 418-696-5056 #201
