[mapserver-users] MapServer and Geopackage failing
Seth G
sethg at geographika.co.uk
Tue Mar 6 14:34:31 PST 2018
Hi Jeff,
I tested on my ms4w installation just now, and didn't get any errors with the above test (MapServer 7.0.4 and GDAL 2.1.3). The same versions of the GISInternals builds did throw the error on the same machine.
Maybe it is related to the sqlite/spatialite libraries?
ms4w:
SQLite 3.19.3
libspatialite 4.3.0-RC1
GISInternals:
sqlite-3.10.2
libspatialite-4.3.0a
Not sure how MapServer would skip the error Even fixed today though.
Regards,
Seth
web:http://geographika.co.uk
twitter: @geographika
On Tue, Mar 6, 2018, at 6:16 PM, Jeff McKenna wrote:
> Hi Seth,
> I was also testing with that same test dataset when you wrote this last
> message. In my testing using MS4W v3.2.5 here (MapServer 7.0.7, GDAL
> 2.2.3) I can display both the v1.2 and v1.0/1.1 test datasets of GPKG.
> (I remember painfully spending a lot of time building spatialite with
> sqlite, for the MS4W community).
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
> On 2018-03-06 12:58 PM, Seth G wrote:
> > Hi,
> > I'm trying to create an image from a Geopackage with MapServer.
> > I can recreate the issue using data from http://www.geopackage.org/#sampledata
> > It appears a v1.1 Geopackage will throw an error if the Sqlite database does not include the Spatialite extension.
> > A v1.2 Geopackage does not seem to produce the same error.
> > Even's patch fixes this error. It also seems the issue disappears when using a dev 2.3.0 build of GDAL.
> > A sample Mapfile using the sample datasets is below. The first shp2img command works, the second does not.
> > MAP
> > # cd /D C:\MapServer\apps\gpkg
> > SIZE 200 200
> > DEBUG 5
> > CONFIG "MS_ERRORFILE" "test.log"
> > CONFIG "CPL_DEBUG" "ON"
> > EXTENT 0 0 10 10
> > SYMBOL
> > NAME "circle"
> > TYPE ELLIPSE
> > FILLED TRUE
> > POINTS
> > 1 1
> > END
> > END
> > LAYER
> > NAME "point2d_v1_2"
> > TYPE POINT
> > DATA "point2d"
> > CONNECTIONTYPE OGR
> > CONNECTION "gdal_sample_v1.2_no_extensions.gpkg"
> > CLASS
> > STYLE
> > SYMBOL "circle"
> > SIZE 10
> > COLOR 0 255 255
> > END
> > END
> > END
> > LAYER
> > NAME "point2d_v1_1"
> > TYPE POINT
> > DATA "point2d"
> > CONNECTIONTYPE OGR
> > CONNECTION "gdal_sample.gpkg"
> > CLASS
> > STYLE
> > SYMBOL "circle"
> > SIZE 10
> > COLOR 0 255 255
> > END
> > END
> > END
> > END
> > On Tue, Mar 6, 2018, at 5:05 PM, Rahkonen Jukka (MML) wrote:
> >> Hi,
> >> Please explain what you are actually doing. Do you wish to use
> >> geopackage for input or output, or both? For rasters, vectors, or both?
> >> If you use gpkg as input I suggest to create the database with GDAL from
> >> some publicly available datasets so others can do the same for
> >> reproducing you case (share your ogr2ogr or gdal_translate commands),
> >> with a complete mapfile that you will hopefully provide as well.
> >> -Jukka Rahkonen-
> >> -----Alkuperäinen viesti-----
> >> Lähettäjä: mapserver-users
> >> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Seth G
> >> Lähetetty: 6. maaliskuuta 2018 12:20
> >> Vastaanottaja: mapserver-users at lists.osgeo.org
> >> Aihe: [mapserver-users] MapServer and Geopackage failing
> >> Hi all,
> >> I'm trying out the geopackage format as an alternative to shapefiles but
> >> running into an issue where MapServer expects the geopackage dataset to
> >> include spatialite. Drawing layers with shp2img logs the following:
> >> [Tue Mar 06 10:39:42 2018].512000 msDrawMap(): rendering using
> >> outputformat named png (AGG/PNG).
> >> [Tue Mar 06 10:39:42 2018].512000 msDrawMap(): WMS/WFS set-up and query,
> >> 0.000s [Tue Mar 06 10:39:42 2018].529000 msOGRFileOpen: Spatialite
> >> support in GPKG not enabled [Tue Mar 06 10:39:42 2018].549000
> >> msOGRFileNextShape(): OGR error. OGR GetNextFeature() error'd. Check
> >> logs.
> >> [Tue Mar 06 10:39:42 2018].549000 msOGRFileNextShape(): In ExecuteSQL():
> >> sqlite3_prepare(SELECT spatialite_version()):
> >> no such function: spatialite_version
> >> [Tue Mar 06 10:39:42 2018].550000 msDrawMap(): Image handling error.
> >> Failed to draw layer named 'ways'.
> >> The spatialite_version function is missing in the geopackage. The
> >> dataset was created by exporting from MapServer as an OUTPUTOPTION:
> >> OUTPUTFORMAT
> >> NAME "GeoPackage"
> >> DRIVER "OGR/GPKG"
> >> FORMATOPTION "STORAGE=memory"
> >> FORMATOPTION "FORM=simple"
> >> FORMATOPTION "FILENAME=result.gpkg"
> >> FORMATOPTION "DSCO:SPATIALITE=YES" # not a listed option, but
> >> tried anyway
> >> FORMATOPTION "LCO:SPATIAL_INDEX=YES"
> >> END
> >> Running a GisInternals build, including GDAL 2.1.3 and MapServer 7.0.4.
> >> Relevant code is at
> >> https://github.com/mapserver/mapserver/blob/aae74ff2abed3f2f8fe1f76c9b4bbccf15023dc1/mapogr.cpp#L1313
> >> It looks like the error should be swallowed up?
> >> The same dataset exported directly to spatilite works fine.
> >> Anyone experienced the above issue?
> >> Regards,
> >> Seth
> >> __
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
