[mapserver-users] DEM
Jean-Christophe Malapert
jcmalapert at gmail.com
Fri Mar 30 00:22:50 PDT 2018
That's a great solution. Thanks a lot.
What about "No data" value ? Is there any way to display this value on the
getCapabilities so that a client can have this information ?
Jean-Christophe
On Thu, Mar 29, 2018 at 7:13 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On jeudi 29 mars 2018 16:36:34 CEST Jean-Christophe Malapert wrote:
> > Hi,
> > I have a DEM with the following information:
> > PROJCS["SimpleCylindrical Moon",
> > GEOGCS["GCS_Moon",
> > DATUM["D_Moon",
> > SPHEROID["Moon",1737400,0]],
> > PRIMEM["Reference_Meridian",0],
> > UNIT["degree",0.0174532925199433]],
> > PROJECTION["Equirectangular"],
> > PARAMETER["latitude_of_origin",0],
> > PARAMETER["central_meridian",0],
> > PARAMETER["standard_parallel_1",0],
> > PARAMETER["false_easting",0],
> > PARAMETER["false_northing",0],
> > UNIT["metre",1,
> > AUTHORITY["EPSG","9001"]]]
> > Origin = (-5458203.076000000350177,2729101.538000000175089)
> > Pixel Size = (118.450587586805568,-118.450587586805568)
> > Metadata:
> > AREA_OR_POINT=Area
> > Image Structure Metadata:
> > INTERLEAVE=BAND
> > Corner Coordinates:
> > Upper Left (-5458203.076, 2729101.538) (180d 0' 0.00"W, 90d 0' 0.00"N)
> > Lower Left (-5458203.076,-2729101.538) (180d 0' 0.00"W, 90d 0' 0.00"S)
> > Upper Right ( 5458203.076, 2729101.538) (180d 0' 0.00"E, 90d 0' 0.00"N)
> > Lower Right ( 5458203.076,-2729101.538) (180d 0' 0.00"E, 90d 0' 0.00"S)
> > Center ( 0.0000000, 0.0000000) ( 0d 0' 0.01"E, 0d 0' 0.01"N)
> > Band 1 Block=92160x1 Type=Int16, ColorInterp=Gray
> > NoData Value=-32768
> > Offset: 0, Scale:0.5
> > From my understanding of the DEM information, each pixel value must be
> > multiplied by 0.5. If I want to access to my DEM through the WCS
> protocol,
> > how can I say to mapserver to multiply each value by 0.5 so that my
> client
> > displays the right values ? If it is not possible, is there a way to have
> > this information in the getCapabilities ?
> Jean-Christophe,
> You can create a VRT that will apply the scaling to raw values (ie multiply
> them by 0.5)
> gdal_translate your.dem unscaled.vrt -of VRT -unscale
> and serve unscaled.vrt with MapServer
> If yo can spare the disk space for a full unscale copy, you can also
> gdal_translate to GeoTIFF.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20180330/a2a5f804/attachment.html>
