[mapserver-users] Using a CRS not indexed by the IOGP
Passmore, James H.
jpass at bgs.ac.uk
Tue Nov 13 08:40:09 PST 2018
Hi Jukka
> I guess the WMS 1.3.0 standard, page 15:
> “Every Layer CRS has an identifier that is a character string. Two types of Layer CRS identifiers are permitted:
> “label” and “URL” identifiers:
> ⎯ Label: The identifier includes a namespace prefix, a colon, a numeric or string code, and in some instances a comma followed by additional parameters. This International Standard defines three namespaces: CRS, EPSG and AUTO2, as discussed below.
> ⎯ URL: The identifier is a fully-qualified URL that references a publicly-accessible file containing a definition of the CRS that is compliant with ISO 19111.
So I can see the reasoning behind MapServer reporting in a GetMap error message that it only supports CRS, EPSG and AUTO2, but the same WMS page also says "This international standard does not mandate support for any particular Layer CRS(s). I take that to read that it should be possible to add support for other CRS outside of those CRS authorities, so ArcGIS WMS might support CRS from ESRI: namespace (CRS authority) for example.
The reason I say GetMap and not GetCapabilities is that it is possible to create a new authority, and reference it in a map file, such that the GetCapabilities response can report it supports a user defined CRS and work out the bounding box extents, it's just when you make a GetMap request, it doesn't work. This is probably the makings of an enhancement request, but perhaps rather than saying MapServer should support any named CRS authority we could suggest to have a user: authority for all custom systems. User: is used by QGIS for example.
James
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system.
UK Research and Innovation has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UK Research and Innovation does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
Opinions, conclusions or other information in this message and attachments that are not related directly to UK Research and Innovation business are solely those of the author and do not represent the views of UK Research and Innovation.
