[mapserver-users] About the granularity of DEBUG on tileindex layers
Seth G sethg at geographika.co.uk
Wed Nov 21 23:56:17 PST 2018
Just to add to the comments on logging, there is a new pull request at
https://github.com/mapserver/mapserver/pull/5707It makes sense to me that it should be possible to turn off logging for
queries not returning features.The tests, and client applications however benefit from a message
saying no results are returned, so the request can't be merged in its
current state.Are there any other examples of returning messages to the user without
logging to follow?
Seth
web:http://geographika.co.uk
twitter: @geographika
On Fri, Nov 16, 2018, at 5:26 PM, Lime, Steve D (MNIT) wrote:
> This isn’t surprising. We haven’t been real good about consistently
> using levels across the code base – cleaning that up would be a good
> project (or sprint activity) and wouldn’t require deep technical
> knowledge.>
> I’ll create a ticket for the case you’ve pointed about below…
> --Steve
> *From:* mapserver-users [mailto:mapserver-users-
> bounces at lists.osgeo.org] *On Behalf Of *Rahkonen Jukka (MML) *Sent:*
> Friday, November 16, 2018 5:48 AM *To:* Mapserver-Users (mapserver-
> users at lists.osgeo.org) <mapserver-users at lists.osgeo.org> *Subject:*
> [mapserver-users] About the granularity of DEBUG on tileindex layers>
> Hi,
> I have always used just ”DEBUG 5” for debugging raster layers but now
> I finally made a test with Mapserver 7.0.1 for seeing what is the real
> difference between the debugging levels. I was a bit surprised to see
> that there is not so much difference at all, and that the DEBUG 1
> level gives information that is missing from the higher debugging
> levels but that would be useful sometimes.>
> Debug 1 prints these lines
> [Fri Nov 16 12:05:50 2018].964589 msDrawRasterLayerLow(layer_name):
> entering.> [Fri Nov 16 12:05:50 2018].980393 msDrawRasterLayerLow(layer_name):
> Filename is: path/file.TIF> [Fri Nov 16 12:05:50 2018].980423 msDrawRasterLayerLow(layer_name):
> Path is: path/file.TIF> [Fri Nov 16 12:05:50 2018].980591 AUTO = +proj=utm +zone=35
> +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs> [Fri Nov 16 12:05:50 2018].980677 msDrawRasterLayerGDAL(): Entering
> transform.> [Fri Nov 16 12:05:50 2018].980687 msDrawRasterLayerGDAL():
> src=9979,8,1786,1062, dst=0,0,1697,1009> [Fri Nov 16 12:05:50 2018].980691 msDrawRasterLayerGDAL(): source
> raster PL (9978.817,7.700) for dst PL (0,0).> [Fri Nov 16 12:05:50 2018].980700 msDrawRasterLayerGDAL():
> red,green,blue,alpha bands = 1,2,3,0>
> All debug levels from level 2 print these lines:
> [Fri Nov 16 12:09:05 2018].581597 msDrawRasterLayerLow(layer_name):
> entering.> [Fri Nov 16 12:09:05 2018].589989 AUTO = +proj=utm +zone=35
> +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs> [Fri Nov 16 12:09:05 2018].590061 msDrawRasterLayerGDAL(): Entering
> transform.> [Fri Nov 16 12:09:05 2018].590069 msDrawRasterLayerGDAL():
> src=2318,7977,1786,1062, dst=0,0,1697,1009> [Fri Nov 16 12:09:05 2018].590073 msDrawRasterLayerGDAL(): source
> raster PL (2317.846,7977.061) for dst PL (0,0).> [Fri Nov 16 12:09:05 2018].590081 msDrawRasterLayerGDAL():
> red,green,blue,alpha bands = 1,2,3,0> [Fri Nov 16 12:09:05 2018].720794 msDrawMap(): Layer 3
> (layer_name), 0.139s>
> The only additional item that debug levels 2 and above give is the
> rendering time msDrawMap that is often useful.  But at the same time
> the filename and path items which are present at debug level 1 are
> missing.>
> I suggest to add debug items msDrawRasterLayerLow(): Filename and
> msDrawRasterLayerLow(): Path should be added alto to debug levels >=2.
> For being even more useful the highest debug level could give also
> timings about reading the tileindex and perhaps separate timings about
> things like how long does it take to read the “src” window from each
> “Filename” and if overviews are used or not.>
> -Jukka Rahkonen-
> _________________________________________________
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20181122/126ec30e/attachment.html>
