[mapserver-users] A couple of mapcache questions
Lime, Steve D (MNIT)
steve.lime at state.mn.us
Wed Oct 10 08:37:13 PDT 2018
Not sure if others replied off-list or not. It's hard to advise on issue 1 since the mapfile and layer definition you sent in the subsequent email was incomplete. Knowing what styles you're using and any min/max scale values would help.
For issue 2 this is what I do for transparent tiles - I think you can just do one or the other but it doesn't hurt to do both:
- set "<transparent>true</transparent>" in the WMS source definition params section.
- set "TRANSPARENT TRUE" in the mapfile (at the map level). You might need to set an IMAGECOLOR too depending on what you're drawing.
In this example:
http://maps1.dnr.state.mn.us/lakefinder/map.html
I only did the latter...
--Steve
-----Original Message-----
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Robert Miller
Sent: Friday, October 05, 2018 3:13 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] A couple of mapcache questions
I'm trying to get my head around mapserver after using geoserver for a
year or so. I'm really impressed so far with the speed and ability of
mapserver. I've got a layer up and running on a WMS service and it
works just I'd like.
My question pertains to mapcache. After a fair amount of head
scratching, I've got mapcache serving up the tiles, but with a couple of
issues...
1. The layer is basically a grid structure - so a bunch of black lines.
When I load the layer in QGIS the lines disappear 5 or 6 zoom levels
out. I adapted the grid from WGS84 (my layer uses epsg:4269), and I
don't really understand resolutions, so I'm thinking that might be the
issue. I tried tweaking the values and everything I did just turned the
whole layer black.
2. Although the mapserver WMS service generates a transparent layer,
webcache is sending me a layer with an opaque white background.
I've tried googling and searching the archive for an understanding of #1
and haven't found anything. As for #2, I don't know where to start. So
any help would be much appreciated.
Thanks,
Bob Miller
mapserver-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapserver-users
