[mapserver-users] Disable automatic metadata in MapServer 7.2
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Fri Oct 19 04:44:07 PDT 2018
Hi James,
Could you make one more test by using the "states.shp" file from the Geoserver demo data and with this mapfile:
MAP
NAME "METADATATEST"
SIZE 800 800
EXTENT -180 -90 180 90
UNITS DD
IMAGECOLOR 20 250 250
SHAPEPATH "c:\ms4w\tmp"
IMAGETYPE "png"
WEB
    METADATA
        "ows_enable_request" "*"
        "wms_srs" "EPSG:4326"
        "wms_onlineresource" "http://localhost:8060/cgi-bin/mapserv.exe?"
    END
END
# DEBUG 5
CONFIG "PROJ_LIB" "C:/ms4w/proj/nad"
CONFIG "CPL_DEBUG" "ON"
CONFIG "MS_ERRORFILE" "c:/ms4w/tmp/debug.txt"
PROJECTION
"init=epsg:4326"
END
LAYER
NAME "states"
STATUS ON
DATA "c:\ms4w\apps\states"
TYPE POLYGON
PROJECTION
       "init=epsg:4326"
END
METADATA
      "wms_title"         "states
END
    CLASS
        STYLE
            COLOR 100 200 100
            OUTLINECOLOR 0 0 0
        END
    END
END
END
Do you still see the metadata links? If you do feel free to include this mapfile and test data into the GitHub issue.
-Jukka-
-----Alkuperäinen viesti-----
Lähettäjä: Passmore, James H. [mailto:jpass at bgs.ac.uk]
Lähetetty: 19. lokakuuta 2018 14:19
Vastaanottaja: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>; mapserver-users at lists.osgeo.org
Aihe: RE: Disable automatic metadata in MapServer 7.2
Hi Jukka,
I disabled the INSPIRE content in my service and I still have the generated metadata sections like below in my layers.
<MetadataURL type="ISOTC211/19115">
<Format>text/xml</Format>
<OnlineResource xlink:type="simple" xlink:href="http://ogc2.bgs.ac.uk/cgi-bin/UGA_ARGI/ows?language=eng&request=GetMetadata&layer=RAILWAY"/>
</MetadataURL>
James
-----Original Message-----
From: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>
Sent: 19 October 2018 12:14
To: Passmore, James H. <jpass at bgs.ac.uk>; mapserver-users at lists.osgeo.org
Subject: Re: Disable automatic metadata in MapServer 7.2
Hi James,
I do not have INSPIRE configurations set and I do not have any metadata links in the body of GetCapabilities.
Without reading the code we can't know if adding INSPIRE stuff adds also something to the body. Fortunately it is easy to test by commenting out everything that seems to relate to INSPIRE in your mapfile. Or write a new as-simple-as-possible mapfile and see how it behaves.
-Jukka-
Lähetetty: 19. lokakuuta 2018 14:09
So I do have INSPIRE configurations set, but the links I refer to are in the body of GetCapabilities response not the INSPIRE extended capabilities section.
Sent: 19 October 2018 12:03
I do not see any metadata links at all in our WMS services made with Mapserver 7.2.0 and I have certainly not disabled them in any way.  I guess that something that you have done has enabled those. Have you played for example with some Inspire configurations?
-Jukka Rahkonen-
Lähettäjä: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Passmore, James H.
Lähetetty: 19. lokakuuta 2018 13:48
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: [mapserver-users] Disable automatic metadata in MapServer 7.2
Is it possible to disable/prevent the automatically created ISO metadata links appearing in WMS GetCapabilities response?
The reason for asking is that at the moment these created links are making the GetCapabilities response invalid.
Thanks
James Passmore
British Geological Survey,
Environmental Science Centre,
KEYWORTH,
United Kingdom,
NG12 5GG
orcid: https://orcid.org/0000-0002-9891-6265
Phone: +44 (0)115 936 3125
Skype: BGSjames
 This message (and any attachments) is for the recipient only. NERC is subject to the Freedom of Information Act 2000 and the contents of this email and any reply you make may be disclosed by NERC unless it is exempt from release under the Act. Any material supplied to NERC may be stored in an electronic records management system.
mapserver-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapserver-users
