[mapserver-users] Need mapfile example for Cascaded WMS GetFeatureInfo request
Daniel Morissette dmorissette at mapgears.com
Wed Sep 5 14:02:11 PDT 2018
If I remember correctly, cascading multi-layer WMS GetFeatureInfo is
only supported if both layers point to the same remote WMS server, i.e.
if the CONNECTION string is identical and the other params (version,
etc) match.
Are both layers pointing to the same WMS server in your test mapfile?
Daniel
On 2018-09-05 4:58 PM, Basques, Bob (CI-StPaul) wrote:
> All,
> I’m not having any luck with getting a GetFeatureInfo request to work
> with more than one layer in the request.
> All works fine with a single layer named, but as soon as more than one
> layer is listed in the request I’m getting a MapServer error:
> <ServiceExceptionReport xmlns="http://www.opengis.net/ogc" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.3.0"xsi:schemaLocation="http://www.opengis.net/ogchttp://schemas.opengis.net/wms/1.3.0/exceptions_1_3_0.xsd">
> <ServiceException code="LayerNotQueryable">
> msWMSFeatureInfo(): WMS server error. Requested WMS layer(s) are not
> queryable: type or connection differ
> </ServiceException>
> </ServiceExceptionReport>
> I’ve been told the “type or connection differ” chunk of message is the
> key part.  Again, individual layer requests
> (LAYERS/QUERY_LAYERS=Layer_01) work just fine, but multiple layers
> (LAYERS/QUERY_LAYERS=Layer_01, Layer_02) do not.
> I’m not finding a lot of info on this online either.  Are there certain
> gothchas to be aware of here?  do I need to look at how each remote WMS
> is being serverd with regard to each GetFetureInfo TEMPLATE?  They all
> work independently, but not in groups.
> Thoughts please.
> Thanks
> bobb
> Even if you’re on the right track, you’ll get run over if you just sit
> there.
> —Will Rogers
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
Daniel Morissette
Mapgears Inc
T: +1 418-696-5056 #201
