[mapserver-users] Forward time and other parameters to a layer defined as wms client
Søren Laursen
sln at fcoo.dk
Fri Aug 9 00:07:57 PDT 2019
That is a very nice and simple solution. Already startet to code and put it in the staging enviroment.
I will put our code on gitlab when we have something that works to create the files etc.
Best regards
Søren
Joint GeoMETOC Support Center
Lautrupbjerg 1-5 - 2750 Ballerup
Danish Defence Acquisition and Logistics Organisation
TLF: +45 7281 5627
MOBIL: +45 2961 9652
FIIN: FMI-MA-OPD07
http://WWW.FCOO.DK/
________________________________________
Fra: trondmm at main.crusaders.no [trondmm at main.crusaders.no] på vegne af Trond Michelsen [trondmm-mapserver+2017 at crusaders.no]
Sendt: 8. august 2019 12:59
Til: Søren Laursen; Mapserver
Emne: Re: [mapserver-users] Forward time and other parameters to a layer defined as wms client
On Thu, Aug 08, 2019 at 10:12:58AM +0000, Søren Laursen wrote:
> Right now I am hacking some code to get GetCapabilities to work in
> our client, because we need some information about the timespan in
> the layer, which mapserver is not forwarding or know any information
> about.
I've made an outputfilter that does the same thing :)
But, you can do it with the regular mapfile, too. I'm using an include
file, so I don't need to rewrite the full mapfile repeatedly.
METADATA
"wms_title" "Radar Nowcast"
"wms_extent" "-790000 7540000 759000 9398000"
"wms_srs" "EPSG:3857 EPSG:3575 EPSG:4326 EPSG:32633 EPSG:32761 EPSG:25833 CRS:84"
INCLUDE "/var/tmp/timeextent.txt"
END
Then timeextent.txt looks like this:
--8<--
"wms_dimensionlist" "modeltime"
"wms_modeltime_item" "foo"
"wms_modeltime_extent" "2019-08-08T10:45:00Z"
"wms_modeltime_default" "2019-08-08T10:45:00Z"
"wms_modeltime_units" "ISO8601"
"wms_timeextent" "2019-08-08T10:45:00Z,2019-08-08T10:50:00Z,2019-08-08T10:55:00Z,2019-08-08T11:00:00Z,2019-08-08T11:05:00Z,2019-08-08T11:10:00Z,2019-08-08T11:15:00Z,2019-08-08T11:20:00Z,2019-08-08T11:25:00Z,2019-08-08T11:30:00Z,2019-08-08T11:35:00Z,2019-08-08T11:40:00Z,2019-08-08T11:45:00Z,2019-08-08T11:50:00Z,2019-08-08T11:55:00Z,2019-08-08T12:00:00Z,2019-08-08T12:05:00Z,2019-08-08T12:10:00Z,2019-08-08T12:15:00Z,2019-08-08T12:20:00Z,2019-08-08T12:25:00Z,2019-08-08T12:30:00Z,2019-08-08T12:35:00Z,2019-08-08T12:40:00Z"
--8<--
This results in this capabilities-output
--8<--
<Dimension name="time" units="ISO8601" nearestValue="0">2019-08-08T10:45:00Z,2019-08-08T10:50:00Z,2019-08-08T10:55:00Z,2019-08-08T11:00:00Z,2019-08-08T11:05:00Z,2019-08-08T11:10:00Z,2019-08-08T11:15:00Z,2019-08-08T11:20:00Z,2019-08-08T11:25:00Z,2019-08-08T11:30:00Z,2019-08-08T11:35:00Z,2019-08-08T11:40:00Z,2019-08-08T11:45:00Z,2019-08-08T11:50:00Z,2019-08-08T11:55:00Z,2019-08-08T12:00:00Z,2019-08-08T12:05:00Z,2019-08-08T12:10:00Z,2019-08-08T12:15:00Z,2019-08-08T12:20:00Z,2019-08-08T12:25:00Z,2019-08-08T12:30:00Z,2019-08-08T12:35:00Z,2019-08-08T12:40:00Z</Dimension>
<Dimension name="modeltime" units="ISO8601" default="2019-08-08T10:45:00Z" multipleValues="1" nearestValue="0">2019-08-08T10:45:00Z</Dimension>
--8<--
Just make sure replacing the old timeextent.txt is an atomic
operation. Otherwise you risk requests coming in just when you've
deleted the old, and before the new is in place. That will cause a 500
Internal Server Error.
Trond Michelsen
