[mapserver-users] The GetFeature WFS Request fail if the layer is empty
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Tue Aug 13 02:45:58 PDT 2019
Thanks for the clarification. As a comparison here is a request and corresponding result for having a look at what Geoserver does
https://demo.geo-solutions.it/geoserver/wfs?service=WFS&version=2.0.0&request=GetFeature&typenames=states&cql_filter=STATE_NAME='Foo'
Result:
<?xml version="1.0" encoding="UTF-8"?><wfs:FeatureCollection xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:wfs="http://www.opengis.net/wfs/2.0" xmlns:gml="http://www.opengis.net/gml/3.2" xmlns:topp="http://www.openplans.org/topp" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" numberMatched="0" numberReturned="0" timeStamp="2019-08-13T09:43:54.633Z" xsi:schemaLocation="http://www.opengis.net/wfs/2.0 https://demo.geo-solutions.it:443/geoserver/schemas/wfs/2.0/wfs.xsd http://www.openplans.org/topp https://demo.geo-solutions.it:443/geoserver/wfs?service=WFS&version=2.0.0&request=DescribeFeatureType&typeName=topp%3Astates http://www.opengis.net/gml/3.2 https://demo.geo-solutions.it:443/geoserver/schemas/gml/3.2.1/gml.xsd"/>
-Jukka-
Lähettäjä: Andrea Peri <aperi2007 at gmail.com>
Lähetetty: tiistai 13. elokuuta 2019 12.35
Vastaanottaja: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>
Kopio: mapserver-users at lists.osgeo.org
Aihe: Re: [mapserver-users] The GetFeature WFS Request fail if the layer is empty
Hi Jukka,
I'm testing with GetFeature using a postgis table.
The table in my test is not empty, but I apply a filter to the query for the data retrieving of the layer and the result with the filter is an empty dataset.
A.
Il giorno mar 13 ago 2019 alle ore 09:00 Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>> ha scritto:
What kind of source dataset do you have, and do you mean that for example a PostGIS table exists but there are no rows in the table?
-Jukka Rahkonen-
Lähettäjä: mapserver-users <mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org>> Puolesta Andrea Peri
Lähetetty: maanantai 12. elokuuta 2019 14.30
Vastaanottaja: mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Aihe: [mapserver-users] The GetFeature WFS Request fail if the layer is empty
I' notice that the GetFeature WFS request of a mapserver (i'm work using master) return an error if the dataset (and so the layer) is empty.
I test using version 1.0.0, 1.1.1 and 2.00.
On 2.0.0 the result is:
http status 400
The request sent by the client was syntactically incorrect.
On 1.1.0 and 1.0.0 the result is an xml exception with:
msWFSGetFeature(): WFS server error. ms_error->code not found
I Guess it should return not an exception or error, but instead an empty GML or an Empty Shapefile and so on...
Before to build a test service of this issue, I like to know if this instead is a confirmed specific characteristic of a wfs service.
Thx,
Andrea Peri
qwerty àèìòù
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20190813/281cf73d/attachment-0001.html>
