[mapserver-users] Map Server configuration in Ubuntu 18.04lts
Stathis G. Arapostathis e.arapostathis at gmail.com
Wed Jan 23 14:46:33 PST 2019
Hi Stefanos,
I ran that command the link existed already. I deleted it and re-executed the command so the link is re created. But still when i type http://localhost/cgi-bin/mapserv I am receiving an error message that the url/mapserv was not found on this server
Any ideas or knowledge on what could be the problem?
Thank you
Stathis
⁣Λήψη του BlueMail για Android ​
Στις 23 Ιαν 2019, 22:09 ,και ώρα 22:09 ,Stefanos Anastasiou <emperor_stef at yahoo.gr> έγραψε:
>HI Stathis,   I think you need to create a symlink between the
>installed mapserv and the the directory that points to cgi-bin in your
>webserver. Something like:  ln -s /usr/local/bin/mapserv
>/usr/lib/cgi-bin/mapserv.
>Regarding the installation you probably installed version 7.0.4 while
>the developers team have announced the release of 7.2 which supports
>php- mapscript for  php7.* now, which is cool. I haven't tried it in my
>machine yet.
>Stefanos
>Στις Τετάρτη, 23 Ιανουαρίου 2019, 9:19:45 μ.μ. EET, ο χρήστης Stathis
>G. Arapostathis <e.arapostathis at gmail.com> έγραψε:
> Hello all,
>I decided to change operating system and installed Ubuntu 18.04lts in
>an old computer I have.
>I successfully installed apache with a sudo command, I can see that is
>running by typing localhost in a browser.
>I also installed cgi-mapserver package with a sudo command however I am
>not sure that it is somehow connected to apache. Is there any certain
>configuration that needs to be done for having a mapserv url like in
>Windows when using the ms4w package? (Something like
>http://localhost/cgi-bin/mapserv ?)
>Thank you
>_______________________________________________
>mapserver-users mailing list
>mapserver-users at lists.osgeo.org
>https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20190124/6d5106ae/attachment.html>
