[mapserver-users] PHP Mapscript styleObj implementation broken?
Nicol Hermann mapserver at geoworld.de
Fri Jan 25 09:17:59 PST 2019
Hello,
after looking closer into the source code I was able to resolve the
issue of setting the 'linecap' property. The property expects
constants. It works if you are specifying one of them:
MS_CJC_NONE (0)
MS_CJC_BEVEL (1)
MS_CJC_BUTT  (2)
MS_CJC_MITER (3)
MS_CJC_ROUND (4)
MS_CJC_SQUARE (5)
MS_CJC_TRIANGLE (6)
MS_CJC_DEFAULT_JOIN_MAXSIZE
However I am still not able to figure out what's going on with the
setPattern() method.
Any hints are greatly appreciated.
Thanks
Nicol
Am Donnerstag, den 24.01.2019, 19:21 +0100 schrieb Nicol Hermann:
> Hello,
> I have huge difficulties to use the styleObj in PHP MapScript
> (Mapserver 7.3-dev, PHP 7.1).
> I am struggling with the setPattern() method and the linecap
> property.
> If I am using
> $styleObj-> setPattern( array( 8.0, 12.0) );
> this gets translated to the following MapFile syntax
> PATTERN
>  4620693217682128896.00 4622945017495814144.00
> END
> The attempt to set the linecap property
> $styleObj-> set('linecap', 'butt' );
> results in
> LINECAP NONE
> Specifying it as integer completely removes the property.
> Can someone please advice if these are bugs or if I am doing
> something
> wrong as this is not documented?
> Thank you very much
> Nicol
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
