[mapserver-users] Mapcache seeder question
Matej Mailing mailing at tam.si
Tue Jul 16 02:24:30 PDT 2019
Yes, it works and the cache directory size is increasing.
V V pon., 8. jul. 2019 ob 17:29 je oseba Lime, Steve D (MNIT)
<steve.lime at state.mn.us> napisala:
> And regular tile generation (no seeding) works ok?
> -----Original Message-----
> From: Matej Mailing [mailto:mailing at tam.si]
> Sent: Monday, July 08, 2019 12:26 AM
> To: Lime, Steve D (MNIT) <steve.lime at state.mn.us>; mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] Mapcache seeder question
> This message may be from an external email source.
> Do not select links or open attachments unless verified. Report all suspicious emails to Minnesota IT Services Security Operations Center.
> Hello Steve,
> thanks for answering. I have changed the extent definition in grid
> declaration, but I still get the "0 tiles needed to be seeded,
> exiting" message back from mapcache_seed.
> Any ideas will be appreciated.
> Thanks,
> Matej
> V V pet., 5. jul. 2019 ob 23:00 je oseba Lime, Steve D (MNIT)
> > I believe the <extent></extent> in your grid should be space delimited - no commas. At least that's how I have things setup, for example...
> > <grid name="mn_utm">
> >     <metadata>
> >       <title>Standard Minnesota UTM Grid</title>
> >     </metadata>
> >     <extent>105000 4785000 809000 5489000</extent>
> >     <srs>epsg:26915</srs>
> >     <size>256 256</size>
> >     <resolutions>5500 2750 1375 687.5 343.75 171.875 85.9375 42.96875 21.484375 10.7421875 5.37109375 2.685546875 1.3427734375</resolutions>
> >   </grid>
> > --Steve
> > From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Matej Mailing
> > Sent: Thursday, July 04, 2019 10:35 AM
> > To: mapserver-users at lists.osgeo.org
> > Subject: [mapserver-users] Mapcache seeder question
> > Hello,
> > I am having issues with running Mapcache Seeder with extent options.
> > My grid is defined like:
> >   <grid name="SLOGRID">
> >     <extent>373233,31868 625985,194134</extent>
> >     <srs>EPSG:3912</srs>
> >     <units>m</units>
> >     <resolutions>180000 90000 45000 22500 11250 5000 2500 1250 600 300
> > 200 100 50 25 12 6 3 1 0.5 0.25 0.12 0.06</resolutions>
> >    </grid>
> > and when I try to run seeder with:
> > mapcache_seed -c mapcache.xml -t dof025 -g SLOGRID -z 3,10 -n 6 -e
> > 533124,86639,544462,103589
> > I get an output 0 tiles needed to be seeded, exiting, which is
> > certainly not true since plenty of those do not exist in the cache
> > directory.
> > What am I missing?
> > Thanks,
> > Matej
> > mapserver-users mailing list
> > https://gcc01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fmapserver-users&data=02%7C01%7Csteve.lime%40state.mn.us%7C202cd663129445fe4f3908d70364db3a%7Ceb14b04624c445198f26b89c2159828c%7C0%7C1%7C636981604044024635&sdata=H7Hfyb9kyJueMQ%2Bh9puMB4C1WyTzrI3I8RzeFqvLXVI%3D&reserved=0
