[mapserver-users] Antw: Re: MapServer with oracle-spatial on a linuxsystem
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Jul 16 10:16:51 PDT 2019
I also took the time to update the OracleSpatial docs
(https://mapserver.org/input/vector/oracle.html). If you have any
enhancements please be sure to file your new issue or pull request to
the "docs" instance at https://github.com/mapserver/docs
thanks!
-jeff
On 2019-07-16 7:24 AM, Kai Behncke wrote:
> Allright, finally I got it.
> I declared:
> export ORACLE_HOME=/usr/lib/oracle/12.2/client64
> export LD_LIBRARY_PATH=${ORACLE_HOME}:/usr/lib
> and in my case I got a problem with the ORACLE_INCLUDE_DIR.
> I changed in the cmake-directory cmake/FindOracle.cmake:
> if(DEFINED ENV{ORACLE_HOME})
> 27
> 28 set(ORACLE_HOME $ENV{ORACLE_HOME})
> 29 message("ORACLE_HOME=${ORACLE_HOME}")
> 30
> 31 find_path(ORACLE_INCLUDE_DIR
> 32 NAMES oci.h
> 33 PATHS
> 34
> 35 /usr/include/oracle/12.2/client64)
> And I configured mapserver by:
> cmake .. -DCMAKE_BUILD_TYPE='debug'
> -DCMAKE_INSTALL_PREFIX=/opt/mapserver
> -DCMAKE_PREFIX_PATH=/usr/lib/oracle/12.2/client64:/usr/include/oracle/12.2/client64:
> /usr/lib:/usr/lib64:/usr/share/gdal -DWITH_ORACLESPATIAL=1
> -DWITH_PROTOBUFC=0 -DWITH_FCGI=0 -DWITH_CURL=1
> and then I got it:
> -- * LIBXML2: /usr/lib64/libxml2.so
> -- * POSTGIS: /usr/lib64/libpq.so
> -- * GEOS: /usr/lib64/libgeos_c.so
> -- * FastCGI: disabled
> -- * PROTOBUFC: disabled
> -- * Oracle Spatial:
> /usr/lib/oracle/12.2/client64/lib/libclntsh.so;/usr/lib/oracle/12.2/client64/lib/libocci.so;/usr/lib/oracle/12.2/client64/lib/libnnz12.so
> -- * Exempi XMP: disabled
> -- * Optional features
> -- * WMS SERVER: ENABLED
> -- * WFS SERVER: ENABLED
> -- * WCS SERVER: ENABLED
> Thank you very much, Kai
> Mit freundlichen Grüßen
> Im Auftrag
> Kai Behncke
> Geoinformation
> Tel.: +49 5451 931-7125
> E-Mail: kai.behncke at ibbenbueren.de <mailto:kai.behncke at ibbenbueren.de>
> Rathaus II
> Roncallistraße 3-5
> 1. Stock, Raum 105
> 49477 Ibbenbüren
>>>> Jeff McKenna <jmckenna at gatewaygeomatics.com> 15.07.2019 18:42 >>>
> Oh and I always use the "Basic" package, but I guess "lite" will work as
> Mike said. -jeff
> On 2019-07-15 1:40 PM, Jeff McKenna wrote:
> > Further to what Mike said, I usually grab the instant client from this
> > page (it is often hard to find):
> https://www.oracle.com/database/technologies/instant-client/downloads.html
> > -jeff
