[mapserver-users] Compiling Mapserver with Oracle Spatial support issue
Steve Lime
sdlime at gmail.com
Tue Aug 25 07:39:43 PDT 2020
Hmmm... Does -DWITH_ORACLESPATIAL=ON (so ON vs 1) make a difference? It
shouldn't... If you do a "ldd mapserv" is the binary linked against the
Oracle libs?
On Wed, Aug 19, 2020 at 12:55 AM Marcin Grudzień <mgrudzien7 at gmail.com>
wrote:
> Hi,
> I am new to Mapserver. I am trying to compile MapServer 7.6.1 with Oracle
> Spatial support on Ubuntu 20.04.
> I basically follow the instruction on
> https://www.mapserver.org/installation/unix.html#.
> To configure my environment I use
> cmake .. -DINSTALL_LIB_DIR:PATH=/usr/lib
> -DCMAKE_PREFIX_PATH="/usr/local;/opt;/usr/lib;/usr/lib/x86_64-linux-gnu;/usr/local/lib;/usr/lib/oracle/11.2/client64/bin;/usr/lib/oracle/11.2/client64/lib"
> -DWITH_CLIENT_WFS=1 -DWITH_CLIENT_WMS=1 -DWITH_CURL=1 -DWITH_SOS=1
> -DWITH_PHP=1 -DWITH_PERL=1 -DWITH_RUBY=0 -DWITH_JAVA=1 -DWITH_CSHARP=0
> -DWITH_PYTHON=1 -DWITH_SVGCAIRO=0 *-DWITH_ORACLESPATIAL=1* -DWITH_MSSQL2008=0
> -DWITH_CURL=1 -DWITH_LIBXML2=1 ../ >../configure.out.txt
> The cmake output shows:
> * Summary of configured options for this build
> -- * Mandatory components
> -- * GDAL: /usr/local/lib/libgdal.so
> -- * PROJ: /usr/lib/x86_64-linux-gnu/libproj.so
> -- * png: /usr/lib/x86_64-linux-gnu/libpng.so
> -- * jpeg: /usr/lib/x86_64-linux-gnu/libjpeg.so
> -- * freetype: /usr/lib/x86_64-linux-gnu/libfreetype.so
> -- * Optional components
> -- * GIF: /usr/lib/x86_64-linux-gnu/libgif.so
> -- * MYSQL: disabled
> -- * FRIBIDI: /usr/lib/x86_64-linux-gnu/libfribidi.so
> -- * HARFBUZZ: /usr/lib/x86_64-linux-gnu/libharfbuzz.so
> -- * CAIRO: /usr/lib/x86_64-linux-gnu/libcairo.so
> -- * SVGCAIRO: disabled
> -- * RSVG: disabled
> -- * CURL: /usr/lib/x86_64-linux-gnu/libcurl.so
> -- * PIXMAN: disabled
> -- * LIBXML2: /usr/lib/x86_64-linux-gnu/libxml2.so
> -- * POSTGIS: /usr/lib/x86_64-linux-gnu/libpq.so
> -- * GEOS: /usr/lib/x86_64-linux-gnu/libgeos_c.so
> -- * FastCGI: /usr/lib/x86_64-linux-gnu/libfcgi.so
> -- * PROTOBUFC: /usr/local/lib/libprotobuf-c.so
> *-- * Oracle Spatial:
> /usr/lib/oracle/11.2/client64/lib/libclntsh.so;/usr/lib/oracle/11.2/client64/lib/libocci.so;/usr/lib/oracle/11.2/client64/lib/libnnz11.so*
> -- * Exempi XMP: disabled
> -- * Optional features
> -- * WMS SERVER: ENABLED
> -- * WFS SERVER: ENABLED
> -- * WCS SERVER: ENABLED
> -- * SOS SERVER: ENABLED
> -- * WMS CLIENT: ENABLED
> -- * WFS CLIENT: ENABLED
> -- * ICONV: ENABLED
> -- * Thread-safety support: disabled
> -- * KML output: disabled
> -- * Z+M point coordinate support: ENABLED
> -- * XML Mapfile support: disabled
> -- * Mapscripts
> -- * Python: ENABLED
> -- * PHP: ENABLED
> -- * PHPNG: disabled
> -- * PERL: ENABLED
> -- * RUBY: disabled
> -- * JAVA: ENABLED
> -- * C#: disabled
> -- * V8 Javascript: disabled
> -- * Apache Module (Experimental): disabled
> -- PROJECT_BINARY_DIR is set to /home/mgrudzien/mapserver-7.6.1/build
> -- Will install files to /usr/local
> -- Will install libraries to /usr/lib
> -- Configuring done
> -- Generating done
> -- Build files have been written to: /home/mgrudzien/mapserver-7.6.1/build
> Then I compile and install MapServer. However, when I execute mapserv -v I
> get
> MapServer version 7.6.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ
> SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=SVG_SYMBOLS
> SUPPORTS=RSVG SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS
> SUPPORTS=GEOS SUPPORTS=POINT_Z_M SUPPORTS=PBF INPUT=JPEG INPUT=POSTGIS
> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> The Oracle Spatial is not supported. What am I doing wrong? How this can
> be solved?
> Best regards,
> Marcin
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20200825/6f7803cb/attachment.html>
