[mapserver-users] mapserver 7.6.2
Stephane Poissant
spoissantca at gmail.com
Wed Dec 30 10:36:42 PST 2020
HI Jeff,
That was a partial success! Thank you for you recommendation!
It compiled successfully by compiling gems and recompiling goal as you suggested.
I still have 1 issue.
While rendering stuff that use to work on previous version, it no longer works in this lates one.
I get AH01215 error in http.
AH01215: GDAL: In GDALDestroy - unloading GDAL shared library.: /var/www/html/map/mapserv.cgi, referer: http://utility.sk.com/ <http://utility.sk.com/>
I am not a developper. It is hard for me to describe where this issue can possibly come from.
It does not render on screen the way it should be.
I will turn back on perl, have ruby, python and php in the makefile as it could be related….
Nevertheless, I would like to thank you for your very quick response and "right on" target answers!
SP
Stéphane Poissant
Portable: 514-793-3506
spoissantca at gmail.com <mailto:spoissantca at gmail.com>
> On Dec 30, 2020, at 10:14 AM, Jeff McKenna <jmckenna at gatewaygeomatics.com> wrote:
> Also, after you compile GEOS be sure to recompile GDAL ('make clean' first), then continue on to tackle your MapServer cmake command.
> Happy new year to all,
> -jeff
> Jeff McKenna
> GatewayGeo: MapServer Consulting and Training Services
> co-founder of FOSS4G
> http://gatewaygeo.com/
> On 2020-12-30 9:56 a.m., Jeff McKenna wrote:
>> Hi Stephane,
>> Be sure to compile GEOS (3.9.0 is recommended from http://download.osgeo.org/geos/geos-3.9.0.tar.bz2 ), and then add into your cmake command: -DWITH_GEOS=1
>> Wishing you a happy new year,
>> -jeff
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20201230/63a2d6b1/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20201230/63a2d6b1/attachment-0001.png>
