[mapserver-users] cgi-error: End of script output before headers mapserv
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Jan 22 06:12:46 PST 2020
Hi Jo,
Are you passing the problem extents to the shp2img utility? Such as:
shp2img -m osm-transp-en-default.map -e -9.1433 38.7460 -9.1406
38.7487 -o ttt.png -all_debug 5
If that doesn't help, then I would start from the beginning: execute a
GetCapabilities request and make sure you remove all "WARNING" messages.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
On 2020-01-22 8:02 a.m., Johannes Paul wrote:
> Thanks for your answer.
> I get the following error output using the command line:
> [Wed Jan 22 06:53:21 2020].530550 CGI Request 1 on process 5157
> [Wed Jan 22 06:53:21 2020].534249 msDrawMap(): rendering using
> outputformat named png (AGG/PNG).
> [Wed Jan 22 06:53:21 2020].534288 msDrawMap(): WMS/WFS set-up and query,
> 0.000s
> [Wed Jan 22 06:53:21 2020].534530 msDrawLabelCache():
> labelcache_map_edge_buffer = 10
> [Wed Jan 22 06:53:21 2020].534577 msDrawMap(): Drawing Label Cache, 0.000s
> [Wed Jan 22 06:53:21 2020].534592 msDrawMap() total time: 0.004s
> [Wed Jan 22 06:53:21 2020].568858 msSaveImage(stdout) total time: 0.034s
> [Wed Jan 22 06:53:21 2020].569291 mapserv request processing time
> (msLoadMap not incl.): 0.039s
> [Wed Jan 22 06:53:21 2020].569318 msFreeMap(): freeing map at 0x1e59fd0.
> On Wed, 22 Jan 2020 at 12:15, Jörg Thomsen (WhereGroup)
> <joerg.thomsen at wheregroup.com <mailto:joerg.thomsen at wheregroup.com>> wrote:
> Hello Jo,
> I don't know this error as parameter-dependent...
> Do you get any error-output on the command line?
> https://mapserver.org/cgi/mapserv.html
> Jörg
> Am 22.01.20 um 12:01 schrieb Johannes Paul:
> > Hello,
> > my mapserver is having a very strange behaviour, which I can't
> explain,
> > nor debug.
> > I'm using mapserver 7.0.0 along with apache http server 2.4.6.
> > Most of the time, the server is working just fine, i.e. when I
> request a
> > typical URL, I get my image back:
> http://10.0.0.22/cgi-bin/mapserv?map=/var/www/html/osm-transp-en-default.map&VERSION=1.1.0&REQUEST=getmap&SERVICE=wms&STYLES=&BBOX=-9.143,38.746,-9.140,38.748&HEIGHT=256&WIDTH=256&LAYERS=default&FORMAT=image/png&SRS=EPSG:4326&TRANSPARENT=true
> > but then, when I slightly change bbox values, I get an internal
> server
> > error (500):
> http://10.0.0.22/cgi-bin/mapserv?map=/var/www/html/osm-transp-en-default.map&VERSION=1.1.0&REQUEST=getmap&SERVICE=wms&STYLES=&BBOX=-9.1433,38.7460,-9.1406,38.7487&HEIGHT=256&WIDTH=256&LAYERS=default&FORMAT=image/png&SRS=EPSG:4326&TRANSPARENT=true
> > I don't get any mapserver error log, but I do get an apache error log
> > saying:
> > [cgi:error] End of script output before headers: mapserv
> > This is really an strange behaviour which I can't explain.
> > Did anyone already experienced a similar situation ?
> > Thanks
> > Jo
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>
> > https://lists.osgeo.org/mailman/listinfo/mapserver-users
> Viele Grüße,
> Jörg Thomsen
> Aufwind durch Wissen!
> Qualifizierte Open-Source-Schulungen
> bei der www.foss-academy.com <http://www.foss-academy.com>
> Jörg Thomsen
> WhereGroup GmbH
> Bundesallee 23
> 10717 Berlin
> Germany
> Fon: +49 (0)30 / 5130 278 74
> Fax: +49 (0)30 / 5130 278 11
> www.wheregroup.com <http://www.wheregroup.com>
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
> Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
> mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
