[mapserver-users] cgi-error: End of script output before headers mapserv
Johannes Paul
johannespaul92 at gmail.com
Wed Jan 22 07:28:58 PST 2020
Thanks for your help.
1. the mapserv cgi command line gave me a proper png (./mapserv -nh
"QUERY_STRING=map=/var/www/html/osm-transp-en-default.map&mode=map" >
/tmp/test.png)
2. i turned on CPL_DEBUG in my mapfile but it doesn't help
3. i ran : shp2img -m /var/www/html/osm-transp-en-default.map -o
/tmp/test.png -all_debug 5 -e -9.1433 38.7460 -9.1406 38.7487 &>
/tmp/shp2img_log.txt
and it looks fine to me...
On Wed, 22 Jan 2020 at 15:28, Jeff McKenna <jmckenna at gatewaygeomatics.com>
wrote:
> The more tests the better :)
> -jeff
> On 2020-01-22 10:21 a.m., Jörg Thomsen (WhereGroup) wrote:
> > Hello Jeff,
> > is shp2img exactly the same as mapserv? (My thought was to use the same
> > executable the webserver calls)
> > Jo,
> > did you get a proper result (image) from your command line request? the
> > 'error'-messages look quite OK.
> > Jörg
> > Am 22.01.20 um 15:12 schrieb Jeff McKenna:
> >> Hi Jo,
> >> Are you passing the problem extents to the shp2img utility? Such as:
> >> shp2img -m osm-transp-en-default.map -e -9.1433 38.7460 -9.1406
> >> 38.7487 -o ttt.png -all_debug 5
> >> If that doesn't help, then I would start from the beginning: execute a
> >> GetCapabilities request and make sure you remove all "WARNING" messages.
> >> -jeff
> > Viele Grüße,
> > Jörg Thomsen
> Jeff McKenna
> MapServer Consulting and Training Services
> https://gatewaygeomatics.com/
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20200122/6549ced6/attachment.html>
