[mapserver-users] MAXSCALEDENOM using runtime var
Steve Lime sdlime at gmail.com
Tue Jun 16 13:56:06 PDT 2020
Hi Scott: Nope, the various scale denominator properties are not mutable
via URL parameters. It's a relatively simple change to make it happen (just
modify maplexer.l (look for the keyword of choice) and rebuild) but I'm not
sure it's a great idea since you could be opening up some performance
headaches for both your mapping box and backend data sources. I mean, a
user could essentially affect at what level high density data could be
drawn at, so imagine asking for high density roads at a global scale from a
remote PostgreSQL/PostGIS source.
--Steve
On Tue, Jun 16, 2020 at 3:36 PM Scott <public at postholer.com> wrote:
> Is it possible to set MAX(MIN)SCALEDENOM using a runtime variable?
> Example:
> MAXSCALEDENOM %maxscaledenom%
> www.postholer.com
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20200616/9eeeedee/attachment.html>
