[mapserver-users] MapScript PHP label with expression and linebreak
Stephen Woodbridge
stephenwoodbridge37 at gmail.com
Sat Mar 28 08:42:46 PDT 2020
On 3/28/2020 10:48 AM, Jean-Philippe Chenel wrote:
> Hi Steve,
> Using MapScript PHP API, WRAP is a integer member.
That sounds like it might be a bug in PHP API because in:
https://mapserver.org/mapfile/label.html
MAXLENGTH [ integer]
WARP [character]
You might want to open a ticket and put in what you have tested.
I would also try making a trivial mapfile with a feature and label it to
see that it works without the PHP mapscript
and then reproduce that in a simple PHP script to submit as examples of
the issue.
Hope this helps,
-Steve
> I've also tried this, but the map isnt rendering.
> $labelObj->set("WRAP", "@");
> Thank you very much for your help
> Jean-Philippe
> *De :* mapserver-users <mapserver-users-bounces at lists.osgeo.org> de la
> part de Stephen Woodbridge <stephenwoodbridge37 at gmail.com>
> *Envoyé :* 28 mars 2020 10:43
> *À :* mapserver-users at lists.osgeo.org <mapserver-users at lists.osgeo.org>
> *Objet :* Re: [mapserver-users] MapScript PHP label with expression
> and linebreak
> When labeling with linebreaks, I insert an unique character like '@', so
> "[field1]@[field2]" and then on the label block add
> WRAP "@"
> Try that and see if it works for you.
> -Steve W
> On 3/28/2020 10:22 AM, Jean-Philippe Chenel wrote:
> > Hi,
> > Using MapScript PHP API, I want to create a label object (using
> > tostring expression) and put 2 columns with a linebreak between them.
> > The example above is working well on a single line, but I don’t know
> > how to make the linebreak (carriage return).
> > $text = "(tostring([vol],'%.2f')+'[vol]')";
> > $classObj = new classObj($layer);
> > $classObj->setText($text);
> > $classObj->addLabel(CreateNewLabel($labelProperties));
> > I've tried multiple combination of \r\n but none of them work (map
> > rendering work, but the label completely disappear).
> > $text = "(tostring([vol],'%.2f') + '\r\n[vol]')";
> > $text = "(tostring([vol],'%.2f') + '\r\n' + '[vol]')";
> > If I don’t use the expression, the line break work
> > $text = "'[vol]\r\n[vol]'";
> > By the way, the TEXT property is on the classObj, the setText method
> > doesn’t work on the labelObj.
> > With best regards,
> > MapServer 7.4.4 (under ubuntu 16.04)
> > PHP 5.6.40
> > Jean-Philippe
> > mapserver-users mailing list
> > https://lists.osgeo.org/mailman/listinfo/mapserver-users
