[mapserver-users] fastcgi performance question
James Gardner
jsg at internode.on.net
Sun Mar 29 15:39:57 PDT 2020
Hi!
I have been doing some benchmarking of mapserver running through
fastcgi, and an experiment with mapserver called through php through
ms_iohandlerequest, running through php seems significantly faster (8x)
than through fastcgi...
the benchmark I am using is a log of GetMap requests from our production
servers...
called through a program called 'siege' with 20 concurrent connections...
my setup is;
ubuntu 18.04 LTS,
gdal-2.4 from ubuntugis stable
mapserver 7.4.1 from ubuntugis-stable
php7.2 from ubuntu-stable
When I hook mapproxy up to /cgi/bin/mapserv?map=
i get 10000 request per 10 minutes answered...
when i hook mapproxy up to /mapser/mapserv.php
I get 80,000 requests per 10 minutes answered...
for a 20 Mb shapefile with 70,000 points to display...
mapserv.php is a php file that parses the url and calls ms_iohandlerequest
mapproxy is set to not cache that particular layer...
I have tried going straight to the fastcgi path /cgi-bin/mapserv?map=
and straight to the php file, but the php file is always faster... if
you want i can
make some docker container scripts to illustrate the point...
does anyone have any ideas what could be causing this difference?
Thanks.
JG.
