[mapserver-users] Mapserver 7.6.1 - PHP 7 Swig - Kml output issue
Jeff McKenna jmckenna at gatewaygeomatics.com
Thu Oct 15 05:42:50 PDT 2020
oops here is the correct command for kml output:
   shp2img -m mymap.map -o ttt.kml -i kml -all_debug 5
(does that generate a valid KML file?)
-jeff
Jeff McKenna
MapServer Consulting and Training Services
co-founder of FOSS4G
http://gatewaygeo.com/
On 2020-10-15 9:41 a.m., Jeff McKenna wrote:
> Hi Bruno,
> What happens if you call that mapfile at the commandline with shp2img
> (and pass the "i" switch with your format name)?  such as:
>    shp2img -m mymap.map -o ttt.png -i kml -all_debug 5
> You can also then try png output:
>    shp2img -m mymap.map -o ttt.png -i png -all_debug 5
> Does it generate a valid map image?
> -jeff
