[mapserver-users] Mapserver 7.6.1 - PHP 7 Swig - Kml output issue
Jeff McKenna jmckenna at gatewaygeomatics.com
Thu Oct 15 08:52:29 PDT 2020
Hi Bruno,
I can trigger this problem with any mapfile that uses an inline FEATURE,
a label, and KML output (only with those 3 combinations enabled, as it
works with other outputformats as SVG).  I don't think it has anything
to do with your settings, as I can trigger that here on Windows/MS4W as
well.
Sorry for the bad news.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
co-founder of FOSS4G
http://gatewaygeo.com/
On 2020-10-15 10:58 a.m., Bruno Domenget wrote:
> Sorry I should have said at first that I already checked that. I have
> both KML and LIBKML drivers listed.
> And KML output works if I remove the LABEL entry from my mapfile...
> Le jeu. 15 oct. 2020 à 09:52, Jeff McKenna
> <jmckenna at gatewaygeomatics.com <mailto:jmckenna at gatewaygeomatics.com>> a
> écrit :
>     Hi Bruno,
>     Next test is to test that your local GDAL was built with KML support:
>         ogrinfo --formats
>     (you should see a 'LIBKML' or 'KML' driver listed there, either one can
>     be used for this)
>     -jeff
>     Jeff McKenna
>     On 2020-10-15 10:48 a.m., Bruno Domenget wrote:
>      > Hi Jeff,
>      > Thanks for your quick answer !
>      > So I tried with shp2img but got the same error with KML output...
>      > *msDrawMap(): Image handling error. Failed to draw layer named
>     'points'.
>      > <br>
>      > GDAL: In GDALDestroy - unloading GDAL shared library.*
>      > Logfile :
>      > [Thu Oct 15 15:36:02 2020].174254 msLoadMap(): 0.005s
>      > [Thu Oct 15 15:36:02 2020].174344 msDrawMap(): rendering using
>      > outputformat named kml (KML).
>      > [Thu Oct 15 15:36:02 2020].174348 msDrawMap(): WMS/WFS set-up and
>     query,
>      > 0.000s
>      > [Thu Oct 15 15:36:02 2020].174369 msINLINELayerOpen: Layer is
>     already open!
>      > [Thu Oct 15 15:36:02 2020].174564
>     msSaveImage(/home/mapserver/public_html/test/././5f885042_26ab_0.png)
>      > total time: 0.000s
>      > [Thu Oct 15 15:36:02 2020].174629 msDrawMap(): Image handling error.
>      > Failed to draw layer named 'points'.
>      > [Thu Oct 15 15:36:02 2020].174649 msFreeMap(): freeing map at
>      > 0x559913f1af60.
>      > [Thu Oct 15 15:36:02 2020].174698 freeLayer(): freeing layer at
>      > 0x559914207ad0.
>      > It works perfectly with PNG output, and with KML output if I
>     remove the
>      > LABEL lines from my mapfile.
>      > So it is not a Mapscript issue, there is definitely an issue with my
>      > Mapserver instance...
>      > Bruno
>      > Le jeu. 15 oct. 2020 à 08:42, Jeff McKenna
>     <mailto:jmckenna at gatewaygeomatics.com>>> a
>      > écrit :
>      >     oops here is the correct command for kml output:
>      >         shp2img -m mymap.map -o ttt.kml -i kml -all_debug 5
>      >     (does that generate a valid KML file?)
>      >     -jeff
>      >     Jeff McKenna
>      >     On 2020-10-15 9:41 a.m., Jeff McKenna wrote:
>      >      > Hi Bruno,
>      >      > What happens if you call that mapfile at the commandline with
>      >     shp2img
>      >      > (and pass the "i" switch with your format name)?  such as:
>      >      >    shp2img -m mymap.map -o ttt.png -i kml -all_debug 5
>      >      > You can also then try png output:
>      >      >    shp2img -m mymap.map -o ttt.png -i png -all_debug 5
>      >      > Does it generate a valid map image?
>      >      > -jeff
