[mapserver-users] tile_map_edge_buffer and python mapscript
Baev Alexandr
oldbay at bk.ru
Mon Apr 5 15:57:06 PDT 2021
Нi Steve: Тhanks for the answer!
Are there features of activating tile mode for mapscript? Whether it is necessary to pass in the request variable mode=tile (as mapserv CGI), or TILED=TRUE (as test in git version https://github.com/MapServer/MapServer/blob/main/msautotest/wxs/wms_tiled.map … something like a geoserver).
By simply including metadata tile_map_edge_buffer - tile buffer does not work for me.
My Mapfile header (this template):
MAP
NAME "test map"
SIZE 1280 1024
MAXSIZE 4096
UNITS meters
IMAGETYPE PNG
EXTENT {{extent_x_min}} {{extent_y_min}} {{extent_x_max}} {{extent_y_max}}
IMAGECOLOR 255 255 255
SYMBOLSET "{{symbolset}}"
FONTSET "{{fontset}}"
WEB
METADATA
"tile_map_edge_buffer" "64"
wms_title "test map"
wms_featureinfoformat "text/plain"
wms_srs "EPSG:3857 EPSG:32638 EPSG:4326"
wms_enable_request "*"
wms_encoding "UTF8"
END
END
PROJECTION
"init=epsg:{{db_epsg}}"
END
LAYER
NAME "test layer"
PROCESSING "LABEL_NO_CLIP=True"
PROCESSING "CLOSE_CONNECTION=DEFER"
PROJECTION
END
METADATA
wms_title "test layer"
END
CONNECTIONTYPE postgis
CONNECTION "{{db_string}}"
DATA "{{query_string}}"
STATUS ON
TYPE POLYGON
Runing this on python mapscript:
map_obj = mapscript.mapObj(mapfile) #mapfile described earlier
request = mapscript.OWSRequest()
mapscript.msIO_installStdoutToBuffer()
request.loadParamsFromURL(query_string) #query_string — request of web framework
status_id = map_obj.OWSDispatch(request)
content_type = mapscript.msIO_stripStdoutBufferContentType()
result = mapscript.msIO_getStdoutBufferBytes()
mapscript.msIO_resetHandlers()
Сan this work in tile mode? Тhanks in advance!
Baev Alexandr
oldbay at bk.ru
>Вторник, 6 апреля 2021, 0:33 +03:00 от Steve Lime <sdlime at gmail.com>:
>Hi Baev: That metadata element is used by the tile mode and by the WMS/GetMap code. So a WMS GetMap request though MapScript should make use of it. --Steve
>On Sun, Apr 4, 2021 at 2:39 PM Baev Alexandr via mapserver-users < mapserver-users at lists.osgeo.org > wrote:
>>Mapserver last release version 7.6.2
>>Will tile_map_edge_buffer work in python mapscript? Or does it only work with mapserv CGI (mode=tile)?
>>If it works, what should be done? Additional configuration may be required mapscript.OWSRequest() ?
>>Help me, please!
>>Baev Alexandr
>>oldbay at bk.ru _______________________________________________
>>mapserver-users mailing list
>>https://lists.osgeo.org/mailman/listinfo/mapserver-users
С уважением,
Baev Alexandr
oldbay at bk.ru
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210406/e0fc1dd3/attachment.html>
