[mapserver-users] Missing Dynamic Charts
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Thu Apr 15 06:28:31 PDT 2021
Hi Sarah,
The easiest way to get the BBOX from QGIS is to open the Debugging/Development tools with the function key F12 or through the View-Panels menu. Start recording and QGIS will capture the http requests including GetMaps for you.
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: mapserver-users <mapserver-users-bounces at lists.osgeo.org> Puolesta Jeff McKenna
Lähetetty: torstai 15. huhtikuuta 2021 16.14
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: Re: [mapserver-users] Missing Dynamic Charts
Hi Sarah,
Thanks for providing links to the data.  I've used your NaturalEarth link, and generated a simple test, with bogus values for the charts, you can see it in your browser at https://ms4w.dev/cgi-bin/mapserv.exe?map=/ms4w/apps/ticket-charting/charts.map&MODE=browse&TEMPLATE=openlayers&LAYERS=all
You can alternatively add it as a WMS (in QGIS for example) with the
onlineresource:
You can see that I cannot replicate your issue (all pie charts show across Canada, with that NaturalEarth admin file).  My full mapfile contains nothing special, no tricks, but is available at:
https://gatewaygeomatics.com/dl/ticket-charting.zip
Some other comments:
- remove DUMP TRUE from your mapfiles as this will break MapServer in the upcoming 8.0 release
- you will notice that I also have no min/max scales set
- to test your issue with your problem mapfile, get the exact problem extent values from QGIS, and then generate a map image with the command:
   shp2img -m mine.map -o ttt.png -map_debug 3 -e minx miny maxx maxy
Give my mapfile a test locally to see also...
Hope that helps!
and hello from the east coast.
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training co-founder of FOSS4G http://gatewaygeo.com/
On 2021-04-14 3:15 p.m., Sarah Zwiep wrote:
> Good afternoon,
> I'm working on a project that's experiencing some unexpected behavior
> with a Mapserver dynamic charts layer. Some polygons in the layer will
> not reliably render charts. For example, at the desired chart size of 30
> and zoom level 4, only 7 of the expected 12 charts render. If we
> increase the zoom level then more of those missing charts will render.
> Similarly, if we decrease the chart size more charts render. However, we
> would like all the charts in view to render regardless of zoom level and
> size, which I believe aligns with the expected behavior of a dynamic
> charts layer.
> We have tried 2 separate vectors files (of Canadian provinces and
> territories) from statcan
> <https://www12.statcan.gc.ca/census-recensement/alternative_alternatif.cfm?archived=1&l=eng&dispext=zip&teng=gpr_000a11a_e.zip&k=%20%20%20%20%202194&loc=http://www12.statcan.gc.ca/census-recensement/2011/geo/bound-limit/files-fichiers/gpr_000a11a_e.zip>
> and naturalEarth
> <https://www.naturalearthdata.com/downloads/50m-cultural-vectors/50m-admin-1-states-provinces/>
> but the problem persists. Neither file has invalid geometries according
> to OGC standards. The project previously used a vector file of Canadian
> ecozones and the charts worked fine with that, so the problem only
> started when we switched the file from ecozones to provinces/territories.
> I've listed links the layer definition, as well of screenshots of the
> project with the missing charts at different sizes/zooms (No chart on
> Nunavut is expected). The project is using MapServer 7.4.4 in Centos 7.9
> and configures the project mapfile as a WMS server for a Leaflet 1.4.0
> WMS layer.
> Any guidance is much appreciated.
> Best regards,
> Sarah
> <https://pasteboard.co/JXk71sR.png>https://pasteboard.co/JXkbqTz.png
> <https://pasteboard.co/JXkbqTz.png>
> <https://pasteboard.co/JXk71sR.png>https://pasteboard.co/JXkbIO4.png
> <https://pasteboard.co/JXkbIO4.png>
> <https://pasteboard.co/JXk71sR.png><https://pasteboard.co/JXkbIO4.png>https://pasteboard.co/JXkc1t1.png
> <https://pasteboard.co/JXkc1t1.png>
> https://pasteboard.co/JXkcgxh.png <https://pasteboard.co/JXkcgxh.png>
> <https://pasteboard.co/JXkcgxh.png>https://pastebin.com/SdudDHNX
> <https://pastebin.com/SdudDHNX>
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
