[mapserver-users] cgi-bin/mapserv double free error on RHEL 8.2
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri Apr 16 15:29:31 PDT 2021
Some quick thoughts before the weekend:
- interesting. And everything is fine with GDAL commands ogrinfo
--formats etc?
- the canned response is:
- compile with CMAKE_BUID_TYPE=DEBUG
- run shp2img (with an error inside your mapfile) in the gdb debugger
(https://mapserver.org/optimization/debugging.html#running-in-the-debugger)
- paste gdb output here (using https://pastebin.com/ ) for everyone
to review (but that is rarely super easy to solve in email)
Not sure. I would also take a look inside your /cgi-bin/ dir and
execute: ldd mapserv (and look for any conflicts with libs) but
that's an awful guess, not easy to see (but I've been here before with
PROJ/GeoTIFF/Spatialite lib conflicts, in this case I'm not sure what lib).
In extreme stress, I would also test with today's checkout of the 'main'
repository from GitHub (recompile with the latest from the repository I
mean).
Sorry, I'm sure others have better advice.
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
On 2021-04-16 3:31 p.m., Worth Lutz wrote:
> Hi All,
> We are having a problem with the cgi mapserv executable.
> Some symptoms are
> * when calling with a valid query string, a png is returned as expected
> * when there is an error in the mapfile, nothing is returned.
> response headers show "Content-Type: text/xml;" but there is no xml
> response data.
> * running mapserv on the command line with the same query string
> returns the expected output.
> * running mapserv -v on the command line returns "double free or
> corruption (out) Aborted (core dumped)"
> gisusr at osagisdevl:~$ mapserv -v
> MapServer version 7.4.3 OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ
> SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=ICONV
> SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
> SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS
> SUPPORTS=POINT_Z_M SUPPORTS=PBF INPUT=JPEG INPUT=POSTGIS INPUT=OGR
> INPUT=GDAL INPUT=SHAPEFILE
> double free or corruption (out)
> This is on a compiled version of mapserver on RHEL8. The same result
> with mapserver 7.6.2.
> Does anyone have suggestions on how to track this problem down?
> *Worth Lutz*
