[mapserver-users] Asking help
Jörg Thomsen (WhereGroup) joerg.thomsen at wheregroup.com
Thu Sep 9 02:04:39 PDT 2021
as mapserver tells you: unable to access file
make very sure that the files exists and the path is correct. If so,
have a look at the access rights, the user www-data must be allowed to
read the mapfile.
By the way it is not a good idea to store the mapfile in the apache home
because it is now accessible via http:/servername/routing.map ->
everyone can read it an find critical information as file-paths and
database connection information ect..
Jörg
And another one: it would be nice, if you could use a more speaking
subject, so it easier to find your questions and answers in the
list-archive.
Am 09.09.21 um 01:26 schrieb Boubacar Bah:
> Hello everyone hope you are fine . Recently l created an interactive
> map  wicth can calculate an itinerary
> And after created a mapefile and the template html
> I used the link below:
> *http://localhost/cgi-bin/mapserv.exe?map=/var/www/html/routing.map&layer=route
> <http://localhost/cgi-bin/mapserv.exe?map=/var/www/html/routing.map&layer=route>
> & mode=browse*
> But the pages send me an errors:
> *MsloadMap():unable to access file.(/var/www/html/routing.map)*
> And l don't how to fix this issues if someone can help me please
> Thanks in advance
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
