[mapserver-users] Floating point exception
Jeff McKenna jmckenna at gatewaygeomatics.com
Fri Apr 8 04:43:02 PDT 2022
Ciao Luca,
I am wondering also if you tried to access the PostGIS data through
ogrinfo yet (to confirm there is no data issue).  Note that I'd
recommend GDAL 3.4.2, PROJ 8.2.1 with MapServer-main.
  ogrinfo -ro PG:"user=xxxx password=xxxx host=127.0.0.1 port=5432
dbname=xxxx" table -summary
Then, follow along the debugging document (
https://www.mapserver.org/optimization/debugging.html ) and add the
following inside your MAP object in mapfile:
   CONFIG "CPL_DEBUG" "ON"
   CONFIG "CPL_TIMESTAMP" "ON"
   CONFIG "PROJ_DEBUG" "ON"
Then re-retry map2img with -all_debug 5, and look for the full SELECT
query made to your database, and run that same query inside psql
commandline.
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
On 2022-04-01 9:22 a.m., Luca Delucchi wrote:
> Hi all,
> I'm getting "Floating point exception" error running shp2img, also
> running with the debug option I don't get any other information.
> The mapfile read data from PostGIS database, and If I use the same
> mapfile with different database with the same tables I don't get this
> error, so I think the problem is in the data but I don't know
> where/what investigate
> thanks in advance
More information about the MapServer-users mailing list
