[MapServer-users] [EXTERNAL] Vector tileindex with connectiontype OGR
Even Rouault
even.rouault at spatialys.com
Wed Dec 7 15:17:37 PST 2022
Pete,
> How do I specify such a query using the OGR PG driver as a Mapserver
> layer to be used as a TILEINDEX of OGR vector files?
A potential solution would be to create a OGR VRT file that contains
your SQL request, and reference that VRT file in the TILEINDEX
<OGRVRTDataSource>
<OGRVRTLayer name="layer">
<SrcDataSource>PG:"host='localhost' user='postgres'
dbname='mydatabase' password='mypwd'</SrcDataSource>
<SrcSQL>SELECT * FROM testtable</SrcSQL>
</OGRVRTDataSource>
Actually you may be able to inline the VRT file as the TILEINDEX value
(it is a bit tricky regarding quoting however, but there's an example of
that in https://mapserver.org/input/vector/VirtualSpatialData.html as
the value of CONNECTION, not TILEINDEX, but that shouldn't make a
difference)), since the OGR VRT XML content can be used as a valid OGR
dataset name.
> Perhaps this is more of a GDAL question... or how does Mapserver's use
> of OGR TILEINDEX of OGR vector files allow custom SQL? Note that as a
> TILEINDEX of Rasters the TILEINDEX can point to a Mapserver Layer, so
> I /can/ add custom SQL queries in that case. But I don't know how to
> do it as a OGR TILEINDEX pointing to OGR vectors.
For vector layer, it doesn't look like it is possible to have TILEINDEX
pointing to a MapServer vector layer (contrary to rasters), at least I
can't see any related tests in mapserver regression test suite
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20221208/8b9aeb86/attachment.htm>
More information about the MapServer-users
