[MapServer-users] WMS Server
Arnold Nicholas Tua Sibuea arnold.nicholas at mastersystem.co.id
Wed Dec 14 05:50:29 PST 2022
Hi ,
Does anywant can give recommendation of the Hardware spec for WMS Server?
Thanks in advance
Arnold
-----Original Message-----
From: MapServer-users <mapserver-users-bounces at lists.osgeo.org> On Behalf
Of mapserver-users-request at lists.osgeo.org
Sent: 14 December 2022 20:48
To: mapserver-users at lists.osgeo.org
Subject: MapServer-users Digest, Vol 179, Issue 22
Send MapServer-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
	https://lists.osgeo.org/mailman/listinfo/mapserver-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
	mapserver-users-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific than
"Re: Contents of MapServer-users digest..."
Today's Topics:
   1. Re: Tileindex in format different than SHP? (Marcin Niemyjski)
Message: 1
Date: Wed, 14 Dec 2022 13:48:03 +0000
From: Marcin Niemyjski <mniemyjski at cloudferro.com>
To: Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>,
	"mapserver-users at lists.osgeo.org"
<mapserver-users at lists.osgeo.org>
Subject: Re: [MapServer-users] Tileindex in format different than SHP?
Message-ID:
<AS1PR03MB81498CEE3CC18529672B3C9CA8E09 at AS1PR03MB8149.eurprd03.prod.outloo
k.com>
Content-Type: text/plain; charset="utf-8"
Jukka,
thanks, I will do more tests.
Marcin
From: Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>
Sent: Wednesday, December 14, 2022 2:36 PM
To: Marcin Niemyjski <mniemyjski at cloudferro.com>; Jeff McKenna
<jmckenna at gatewaygeomatics.com>; mapserver-users at lists.osgeo.org
Subject: VS: [MapServer-users] Tileindex in format different than SHP?
You are wrong, a GeoPackage layer as a tileindex is about as fast as a
shapefile in common bbox filtering that WMS is, and faster than shapefile
index if you want to filter or sort the data by other attributes. That is
based on my measurements from some years ago with an orthophoto layer
having about 80000 rows in the index. Your data can be different but make
a proper test and then jugde by the facts. There is no need to render the
tileindex layer once you have made it to work. However, it does offer a
handy way for letting your users to query metadata from the individual
images with GetFeatureInfo if you happen to have that kind of needs.
-Jukka Rahkonen-
L?hett?j?: MapServer-users <mapserver-users-bounces at lists.osgeo.org>
Puolesta Marcin Niemyjski via MapServer-users
L?hetetty: keskiviikko 14. joulukuuta 2022 15.08
Vastaanottaja: Jeff McKenna <jmckenna at gatewaygeomatics.com>;
Aihe: Re: [MapServer-users] Tileindex in format different than SHP?
Jeff,
I checked TILEINDEX documentation before writing to you. I found no
information's about other formats except that shapefile is usually used.
Jukka,
I created an extra layer as you suggested, thanks - it works, but I will
stay with Shapefiles on this one. When working with tileindex as extra
layer it takes 2x more time for mapserver to render the layer.
Thank you all,
Marcin
<mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at li
sts.osgeo.org>> on behalf of Jeff McKenna
<jmckenna at gatewaygeomatics.com<mailto:jmckenna at gatewaygeomatics.com>>
Sent: Wednesday, December 14, 2022 1:51 PM
To:
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
<mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>>
I had recently spent a few weeks of effort on updating the documentation
for TILEINDEX, with many examples, see :
https://mapserver.org/optimization/tileindex.html<https://eur06.safelinks.
protection.outlook.com/?url=https%3A%2F%2Fmapserver.org%2Foptimization%2Ft
ileindex.html&data=05%7C01%7Cjukka.rahkonen%40maanmittauslaitos.fi%7C97a0f
f74ad814a33ecf308daddd43c70%7Cc4f8a63255804a1c92371d5a571b71fa%7C0%7C0%7C6
38066200868945991%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2lu
MzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=Ytab2HUFqvSlThcIl
Mrw0uEOTYkcvUQNLwy3knjGS7s%3D&reserved=0>
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/<https://eur06.safelinks.protection.outlook.com/?url
=http%3A%2F%2Fgatewaygeo.com%2F&data=05%7C01%7Cjukka.rahkonen%40maanmittau
slaitos.fi%7C97a0ff74ad814a33ecf308daddd43c70%7Cc4f8a63255804a1c92371d5a57
1b71fa%7C0%7C0%7C638066200868945991%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLj
AwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata
=jVo90DcKenZPc641ZN6rpbnlQmHEOick7VDCP%2BQxBoM%3D&reserved=0>
On 2022-12-14 7:23 a.m., Marcin Niemyjski via MapServer-users wrote:
> Hello,
> Can I use format different than SHP while using tileindex of rasters?
> When using Mapfile with configuration as below:
> LAYER
>         ?????NAME "2021-01-02_high"
>          STATUS ON
>          TILEINDEX
"/DyskPlanetiler/Sentinel1COG/2021/01/02/2021-01-02.gpkg"
>          TILEITEM "location"
>          TYPE RASTER
>          MAXSCALEDENOM 4000000
>          GROUP "2021-01-02"
>          PROJECTION
>              "init=epsg:4326"
>          END
> END
> error is recived:
> msShapefileOpen(): Unable to access file.
> (/DyskPlanetiler/Sentinel1COG/2021/01/01/2021-01-01.gpkg)
> is there a way to use geopackage or flatgeobuf as indexes or do I have
> to go back to shp?
> Best,
> Marcin
> MapServer-users at lists.osgeo.org<mailto:MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users<https://eur06
> .safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2
> Fmailman%2Flistinfo%2Fmapserver-users&data=05%7C01%7Cjukka.rahkonen%40
> maanmittauslaitos.fi%7C97a0ff74ad814a33ecf308daddd43c70%7Cc4f8a6325580
> 4a1c92371d5a571b71fa%7C0%7C0%7C638066200868945991%7CUnknown%7CTWFpbGZs
> b3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D
> %7C3000%7C%7C%7C&sdata=uBO9pSmK8xEv5WITuBjAfQJ26kes%2FdMM4gS4KQdH85o%3
> D&reserved=0>
MapServer-users at lists.osgeo.org<mailto:MapServer-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/mapserver-users<https://eur06.saf
elinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman
%2Flistinfo%2Fmapserver-users&data=05%7C01%7Cjukka.rahkonen%40maanmittausl
aitos.fi%7C97a0ff74ad814a33ecf308daddd43c70%7Cc4f8a63255804a1c92371d5a571b
71fa%7C0%7C0%7C638066200868945991%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAw
MDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=u
BO9pSmK8xEv5WITuBjAfQJ26kes%2FdMM4gS4KQdH85o%3D&reserved=0>
URL:
<http://lists.osgeo.org/pipermail/mapserver-users/attachments/20221214/012
f3396/attachment.htm>
Subject: Digest Footer
End of MapServer-users Digest, Vol 179, Issue 22
More information about the MapServer-users mailing list
