[mapserver-users] getting the scale in a map file at runtime
Richard Greenwood
richard.greenwood at gmail.com
Fri Jun 3 08:00:57 PDT 2022
On Fri, Jun 3, 2022 at 8:43 AM Jörg Thomsen (WhereGroup) <
joerg.thomsen at wheregroup.com> wrote:
> Richard,
> sorry, yes, sure...
> Perhaps you can use scaletoken? It's not the same as you are searching
> for, but you could define a set of tolerance-values for different scales.
Yes - I had not thought of that. It might be a better way than what I was
trying to do. Thank you!
Am 03.06.22 um 16:21 schrieb Richard Greenwood:
> > On Fri, Jun 3, 2022 at 8:00 AM Jörg Thomsen (WhereGroup)
> > <joerg.thomsen at wheregroup.com <mailto:joerg.thomsen at wheregroup.com>>
> wrote:
> > Hi,
> > what about:
> > https://mapserver.org/mapfile/template.html#image-geometry
> > <https://mapserver.org/mapfile/template.html#image-geometry>
> > -> scaledenom
> > Doesn't work?
> > Thanks, but no, it does not work. I'm trying to access the scale in a
> > map file, not in a template. Using square brackets [variable] is
> > interpreted as a field name in the data, not as a runtime variable. For
> > example:
> > CLASS
> > STYLE
> > GEOMTRANSFORM (generalize([shape], [scaledenom]))
> > COLOR "#2AB1F7"
> > END
> > END
> > returns the error:
> > DBASE file error. Item 'scaledenom' not found.
> > Jörg
> > Am 03.06.22 um 15:45 schrieb Richard Greenwood:
> > > Can I get the current scale for use in a map file at runtime.
> > > Specifically, I'd like to use it in a geotransform something like:
> > > GEOMTRANSFORM (generalize([shape], [scale]))
> > > or more likely for use in an expression:
> > > GEOMTRANSFORM (generalize([shape], [scale] / 100))
> > > Thanks
> > > Richard W. Greenwood
> > > www.greenwoodmap.com <http://www.greenwoodmap.com>
> > <http://www.greenwoodmap.com <http://www.greenwoodmap.com>>
> > > _______________________________________________
> > > MapServer-users mailing list
> > > MapServer-users at lists.osgeo.org
> > <mailto:MapServer-users at lists.osgeo.org>
> > > https://lists.osgeo.org/mailman/listinfo/mapserver-users
> > <https://lists.osgeo.org/mailman/listinfo/mapserver-users>
> > Viele Grüße,
> > Jörg Thomsen
> > Aufwind durch Wissen!
> > Jetzt neu: Web-Seminare und Online-Schulungen
> > bei der www.foss-academy.com <http://www.foss-academy.com>
> > Jörg Thomsen
> > WhereGroup GmbH
> > Bundesallee 23
> > 10717 Berlin
> > Germany
> > Tel: +49 (0)30 / 5130 278 74
> > Fax: +49 (0)30 / 5130 278 11
> > www.wheregroup.com <http://www.wheregroup.com>
> > Geschäftsführer:
> > Olaf Knopp, Peter Stamm
> > Amtsgericht Bonn, HRB 9885
> > Folgen Sie der WhereGroup auf twitter:
> > http://twitter.com/WhereGroup_com <http://twitter.com/WhereGroup_com
> > MapServer-users at lists.osgeo.org <mailto:
> Viele Grüße,
> Jörg Thomsen
> Jörg Thomsen
> WhereGroup GmbH
> Bundesallee 23
> 10717 Berlin
> Germany
> www.wheregroup.com
> Geschäftsführer:
> Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20220603/6a5e4ba9/attachment-0001.htm>
More information about the MapServer-users
