[MapServer-users] wms time validation of time parameter against timeextent gives unexpected results
Steve Lime sdlime at gmail.com
Mon Feb 6 08:48:26 PST 2023
Does WMS 1.1 behave the same? I suppose it comes down to how 2022 is
interpreted as part of a range, I would have expected it would mean any
date in that year. Sounds like it's behaving like strictly less than
2022-01-01. What happens if you set the range using full dates, so
something like: 20050101/20221231?
--Steve
On Thu, Feb 2, 2023 at 3:33 AM Clausen Marcel via MapServer-users <
mapserver-users at lists.osgeo.org> wrote:
> Dear all
> We have the following question concerning the configuration and usage of
> time enabled wms layers.
> We are using the following metadata section for a time-enabled layer:
>     METADATA
>         "wms_enable_request" "*"
>         "wms_title" "lubis_bildstreifen"
>         "wms_extent" "2100000 1050000 2850000 1400000"
>         "wms_timeextent" "2005/2022"
>         "wms_timeitem" "flugdatum" # this is a date column in postgres
>     END
> The time precision/resolution of the timeextent has to be set as year.
> The validation of the time parameter against the time extent with year
> precision gives some strange results. We were using the following getmap
> request for the tests:
> localhost:7777/local/?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&FORMAT=image/png&TRANSPARENT=true&LAYERS=ch.swisstopo.lubis-bildstreifen&CRS=EPSG:2056&STYLES=&WIDTH=860&HEIGHT=600&BBOX=2420000,1050000,2850000,1350000&TIME=2022
> parameter:              time=2005
> result:                         returns all features of 2005
> expected result:        ok
> parameter:              time=2022
> result:                         returns all features of 2022
> expected result:        ok
> parameter:              time=2023
> result:                         returns ServiceException [1]
> expected result:        ok
> parameter:              time=2022-01-01
> result:                         returns ServiceException [2]
> expected result:        we would expect this to be a valid timestamp
> parameter:              time=2022-01-01/2022-12-31
> result:                         returns ServiceException [3]
> It seems that if the precision of the time parameter is of YYYY-MM or
> YYYY-MM-TT the upper bound of the defined timextent 2005/2022 is not
> respected correctly.
> We got the same result with the timextent defined  as: 2005/2022/P1Y
> our mapserver version is:
> <!--  MapServer version 7.6.4 OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML
> SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO
> SUPPORTS=SVG_SYMBOLS SUPPORTS=RSVG SUPPORTS=ICONV SUPPORTS=FRIBIDI
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER
> SUPPORTS=FASTCGI SUPPORTS=GEOS SUPPORTS=POINT_Z_M SUPPORTS=PBF INPUT=JPEG
> INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE  -->
> Does someone have some insights or hints?
> Best regards
> Clausen Marcel
> [1]
> <ServiceException code="InvalidDimensionValue">msWMSApplyTime: WMS server
> error. Time value(s) 2023 given is invalid or outside the time extent
> defined (2005/2022).</ServiceException>
> [2]
> <ServiceException code="InvalidDimensionValue"> msWMSApplyTime: WMS server
> error. Time value(s) 2022-01-01 given is invalid or outside the time extent
> defined (2005/2022). </ServiceException>
> [3]
> error. Time value(s) 2022-01-01/2022-12-31 given is invalid or outside the
> time extent defined (2005/2022). </ServiceException>
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20230206/a4217f6b/attachment.htm>
More information about the MapServer-users mailing list
