[MapServer-users] MSSQL plugin path outside of the global CONFIG file
Jörg Thomsen (WhereGroup) joerg.thomsen at wheregroup.com
Mon Mar 20 07:13:32 PDT 2023
Hello Benedek,
 > Is it mandatory now, to define the PLUGIN path from the global CONFIG
file?
short answer: yes it's mandatory and it's a security issue.
the documentation is very explizit
(see https://mapserver.org/mapfile/layer.html):
> For MapServer >=8:
defining plugins for dataconnections in the config-gile
> For MapServer <8:
defining plugins for dataconnections in the mapfile
further in https://mapserver.org/mapfile/config.html :
> This block allows for keys to be mapped to plugin library paths.
 > For example the MS SQL Plugin.
 > **This registry of plugins avoids possible unsafe libraries being
 >  loaded by a mapfile.**
Regards, Jörg
Am 20.03.23 um 14:51 schrieb Benedek Petrovicz:
> Hi!
> Before MapServer 8, I always defined the mssql plugin path in the
> mapfiles directly.
> It was a convenient way for my use case.
> Now from MapServer 8 there's the required global CONFIG file I have to
> define.
> Which is fine, but MapServer will only allow loading the plugin through
> that global CONFIG file.
> The CONFIG reference states the following:
>     /"PLUGINS: This block allows for keys to be mapped to plugin library
>     paths."/
> For me, this means I can define a global plugin keyword if I want to,
> but I don't have to.
> In reality I don't have other options. At least I don't know about any.
> Is it mandatory now, to define the PLUGIN path from the global CONFIG file?
> Thank you!
> Benedek Petrovicz
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
Viele Grüße,
Jörg Thomsen
Aufwind durch Wissen!
Web-Seminare und Online-Schulungen
bei der www.foss-academy.com
Jörg Thomsen
WhereGroup GmbH
Bundesallee 23
10717 Berlin
Germany
Tel: +49 (0)30 / 5130 278 74
Fax: +49 (0)30 / 5130 278 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
More information about the MapServer-users mailing list
